New clutch problems, Help?
Old Sep 17, 2004 | 08:12 AM
Johng316's Avatar
Hi all,
I burned my stock clutch out at 23K miles, so I bought the ACT street disc clutch and a Fidanza flywheel and brought the parts to a local well-known speed shop for install. They also put in a SS clutch line while they were in.
I have about 160 miles on the install now, and I'm noticing some stuff that worries me. I need to know if these symptoms are serious or are just part of a new aftermarket clutch breaking in. I have never used an aftermarket clutch, so I am not sure!
During normal (calm) operation, the clutch is fine and engages properly. But when I put the clutch under any load (starting at 4K RPM and slipping the clutch, hard acceleration in 2nd), I get a front-end shudder I can feel through the gas pedal.
After the clutch engages, I can hear and feel a rapid B-B-B-B-B-Bump! On launch, sometimes I also hear a scraping noise coming from the front-end.
What could this be?
Is this normal with this clutch?
Do I need an adjustment?
Is something in my drivetrain breaking?
Any ideas on what this could be?
Thanks!
John
Old Sep 19, 2004 | 04:23 PM
Johng316's Avatar
Anyone?
I'm taking this back to the shop to see if they can diagnose the shudder/bump tomorrow. I'll try to post here before I buzz off to South America on Tuesday.
Nobody else has had the prob?
John
Old Sep 21, 2004 | 08:02 AM
Johng316's Avatar
OK, the shop figured out the problem.
One of the rear engine mount bolts had backed out, so when the engine went under torque load, it would buck and shudder.
Bolt replaced and tightened down, and now everything is as smooth as a baby's backside.
John
Old Sep 21, 2004 | 08:14 AM
raywong's Avatar
John, thanks for letting us know!
Old Sep 21, 2004 | 08:15 AM
Stinkapuss's Avatar
When I had my 2nd clutch put in Mitsubishi forgot to tighten my rear engine mount also.
Old Sep 21, 2004 | 08:38 AM
raywong's Avatar
My car shudders violently when I remove my left foot quickly in 1st gear. Is it considered normal?
