Gains: BR Stage 3 versus BR Stage 4+BR440
Well, I finally finished installing and sorting out most of the issues I had encountered while installing my upgrade from a BR Stg3 to a BR Stg 4 + BR440. (None of the issues were directly related to the turbo kit or other Stg 4 parts... big thanks to David Buschur for dealing with my crap and getting me the parts I needed to replace.)
After all was said and I done I was quite happy with the increase in power. I was kind of curious to see how much of an improvement the new turbo made. Since I didn't do any baselines on a stationary dyno I pulled some old log data I had collected last April. I overlaid this data with a pull I did last night with the Stage 4 + BR440 and plotted the two runs. I think the Stage 3 numbers correspond with quoted figures I've seen for the BR Stage 3 on a Dynojet (290-320whp). If the numbers are in the ballpark, I'm pretty happy with them. Based on the performance of the Stage 3 at trackdays, I think the numbers are pretty close. In the straights I could usually walk E43 M3s, keep up with Z06s and at my last track event, I totally bewildered a guy in an '04 AMG E55. He couldn't figure out why he couldn't walk me in the straights.
What I'm really happy with is the spool and the huge increase of torque across the rpm band. The strong pull all the way to the redline is great too. It absolutely slams into the rev limiter now. The new turbo is also really loud. Even with the Magnaflow option on the BR exhaust it almost sounds like a sport bike when at WOT.
Bear in mind that these numbers are rough estimates. The weather conditions for each of the days that this data was collected were different. I have no way of plugging in any kind of correction factors to compensate for humidity or temperature. Regardless, the gains are significant and the spool is very close to stock. I think with a further amount of fine tuning, spool up could be improved. I might investigate what sort of gains can be had with a mildly ported and polished head.
Boost: ~20psi
Octane: 93
Stg 3: High flow cat
Stg 4+: Catless
Note: "Custom Flash" = Dynoflash
Boost: ~20psi
Octane: 93
Stg 4+: Catless
Originally Posted by matt55
If both "runs" are close to the same conditions thats a nice , REALY nice gain in HP !
As I said, I'm really happy with the spool and top end pull. I was afraid the 440 would be slow to spool and too laggy. Eventually I'll get the car to a dyno day and see if I can compare it to other cars under similar ambient conditions.
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
I am impressed with the spoolup. There isn't near the lag I thought there would be. You only loose a little down low and by 4400 rpm it's a totally different beast.
I was not tryin to take anything away from you , 50-60 hp is a dam good bolt on , @ 20psi and on pump gass ... keep us updated
Correction Factor Calculator
Farmer's Almanac Historical Weather Data
Originally Posted by propellerhead
No, it's all good. I should have crunched the numbers little better. I went back and looked at historical data for that first run and plugged in the data into a correction factor calculator I found on the net. I *think* those figures are within 5% or so, 10% at worst case which would put it around a 65hp gain.
Man you got to take it to the track
, this is the 3rd or 4th time ive looked at your graph and said "wow" .
Neat
Any worries running that much power while roadracing / track events. I'm just curious of the logevity of the engine. If it works our well, this would make a very fast track car. (Faster than they already are...
Yep. 264s.
Complete mod list:
Buschur Racing FMIC
Buschur Racing Upper Intercooler Pipe
Buschur Racing 3" TB Exhaust (currently using off road pipe)
Buschur Racing Mini Battery
Buschur Racing Intake & Cone Filter
BR440 Turbo kit
HKS 264/264 Cams
Hallman MBC
ARP head bolts
Dynoflash custom tune
ECU+ (currently 'out of band'. Provides SAFC-like functionality, timing adjustment & extensive datalogging)
Other stuff:
Autometer Cobalt electronic boost gauge
Defi D-series Oil Pressure/Temp
Innovative Motorsports Wideband O2 w/ dash mounted analog gauge.
Stasis Rotors
Complete mod list:
Buschur Racing FMIC
BR440 Turbo kit
HKS 264/264 Cams
Hallman MBC
ARP head bolts
Other stuff:
Stasis Rotors
