My HTA dyno results (more boost)
Well I finally got it done. After leaking from one part or another, the guys at Dyno4mance got me straight. Here it is.
http://i234.photobucket.com/albums/e...177WHP_WTQ.jpg http://i234.photobucket.com/albums/e...177PSI_AFR.jpg http://i234.photobucket.com/albums/e...177WHP_Run.jpg |
So what does it run? Well I did what I could do. I have to get better at driving. The car is definatly better than the driver.
http://i234.photobucket.com/albums/e...th_EVO7395.jpg http://i234.photobucket.com/albums/e.../7395_slip.jpg That's a 7.3@95 in the 1/8, just incase the printout isn't clear enough. It was straight test and tune, and the 1st day they where open. |
nice numbers, what mods besides hta?
How much boost are you pushing on her? The 1/8 mile traps are not the best test for the true pull of that turbo , being that it never gets into 4th gear which would be the true test to H.P. with the closest 1:1 gear ratio. Plus the 1/8 mile mph. vs the 1/4 mile mph is a good indicator of how much power is being produced. If you pull 30+ mph on the back half your on track
You running standalone?
Originally Posted by steelcityevo8
(Post 5154814)
Originally Posted by zbomb
(Post 5154820)
Originally Posted by LT1runner
(Post 5154829)
Just ECU flash with MAF-T Pro for the speed density conversion.
Originally Posted by nikkadanny
(Post 5154796)
517whp on dyno dynamics is no joke man! That's some awesome power! Now practice driving and get her down the track for a some good 1/4 mile times! I'm seriously jealous...
Am I reading the AFR correctly that you are tuned to ~10.2 AFR for the most part?
also, what alky kit are you running?
Try to shift faster.
Originally Posted by scheides
(Post 5154923)
Originally Posted by EVO8LTW
(Post 5154932)
(Post 5154941)
Originally Posted by evovin
(Post 5155219)
I'm always confused about Dyno Dynamics dyno results because I never know if they are the ones that are trying to read like Dynojets or not.
In the UK that power would be thought to be around 680 hp at the crank. Why does Dyno4mance not include the data at the bottom of the sheet for the run like a sheet like this does? http://www.lancerregister.com/attach...postid=1397336 |
