Holding more boost at redline
Hey everyone. I have an Evo IX with all the bolt-ons, ported exhaust mani, o2, hotside, etc. My car holds 28psi till about 6k and drops to 21.5psi at 7k. Anyways I can hold more boost by redline?
:beer::beer::beer: |
ecu boost
What are you using for a BCS?
3 port boost solenoid & crushed MR BOV would help.
I have ECU boost with crushed BOV. The WGDC is at 100 by 6k rpm.
Originally Posted by xmaciek82x
(Post 9057114)
Originally Posted by achilles3000
(Post 9057127)
The most my stock turbo ever held was 26 psi till redline and peak was 28..I had a blox mbc clone of the hallman and was better in terms of spool and the way it held when compared to the hallman funny thing was I paid $70 for it.
(Post 9057145)
Stock wastegate actuator?
Yes when I had my fp red held 31 psi till redline...Maybe try preloading it??Once I get retuned from a past tuner my car held boost like crazy. |
(Post 9057194)
Yea. It,s preloaded. It won't go any more. Not sure what is going on then. |
Checked for any boost leaks?
Also, the tune can be a factor on how you hold boost. (not the boost tune) |
(Post 9057089)
Hey everyone. I have an Evo IX with all the bolt-ons, ported exhaust mani, o2, hotside, etc. My car holds 28psi...:beer::beer::beer:
Even if you got more boost up there the power wouldnt increase from the heat. 22 to 23 at 7500 is about it for HP
Originally Posted by C6C6CH3vo
(Post 9057354)
? makes no sense for this thread. |
(Post 9057365)
have you tried the help spring? there is a how to in the engine section...
https://www.evolutionm.net/forums/ev...pring-mod.html and try the dejon tools mr bov stop leak trick https://www.evolutionm.net/forums/ev...it-mr-bov.html when i did these on my stocker i was well into 30psi.. gauge max.. and it never tapered back into range... add a water/meth kit for cooling and upgraded intercooler and enjoy your new power... |
