Holding more boost at redline
Old Feb 7, 2011 | 07:47 PM
xmaciek82x's Avatar
Hey everyone. I have an Evo IX with all the bolt-ons, ported exhaust mani, o2, hotside, etc. My car holds 28psi till about 6k and drops to 21.5psi at 7k. Anyways I can hold more boost by redline?
Old Feb 7, 2011 | 07:48 PM
BLK_EvIL's Avatar
ecu boost
SiliconTek's Avatar
What are you using for a BCS?
Old Feb 7, 2011 | 07:49 PM
FedEvo8's Avatar
3 port boost solenoid & crushed MR BOV would help.
Old Feb 7, 2011 | 07:54 PM
xmaciek82x's Avatar
I have ECU boost with crushed BOV. The WGDC is at 100 by 6k rpm.
Old Feb 7, 2011 | 07:58 PM
achilles3000's Avatar
The most my stock turbo ever held was 26 psi till redline and peak was 28..I had a blox mbc clone of the hallman and was better in terms of spool and the way it held when compared to the hallman funny thing was I paid $70 for it.
Old Feb 7, 2011 | 08:04 PM
xmaciek82x's Avatar
Stock wastegate actuator?
Old Feb 7, 2011 | 08:21 PM
Yes when I had my fp red held 31 psi till redline...Maybe try preloading it??Once I get retuned from a past tuner my car held boost like crazy.
Old Feb 7, 2011 | 08:32 PM
xmaciek82x's Avatar
Yea. It,s preloaded. It won't go any more. Not sure what is going on then.
Old Feb 7, 2011 | 08:48 PM
BluEVOIX's Avatar
Checked for any boost leaks?
Also, the tune can be a factor on how you hold boost. (not the boost tune)
Old Feb 7, 2011 | 08:56 PM
sparky's Avatar
Hey everyone. I have an Evo IX with all the bolt-ons, ported exhaust mani, o2, hotside, etc. My car holds 28psi...
Actually, you should feel blessed at being able to hold 28# with a IX turbo. the USDM IX turbo is the worst and most classical case of boost taper among the many 16G configurations that I am aware of.
Old Feb 7, 2011 | 09:26 PM
C6C6CH3vo's Avatar
Even if you got more boost up there the power wouldnt increase from the heat. 22 to 23 at 7500 is about it for HP
Old Feb 7, 2011 | 09:29 PM
? makes no sense for this thread.
Old Feb 7, 2011 | 09:37 PM
SiliconTek's Avatar
Exceeding the efficiency of the turbo at redline, sounds pretty reasonable to me.
Old Feb 7, 2011 | 09:38 PM
joseph143's Avatar
have you tried the help spring? there is a how to in the engine section...
https://www.evolutionm.net/forums/ev...pring-mod.html
and try the dejon tools mr bov stop leak trick
https://www.evolutionm.net/forums/ev...it-mr-bov.html
when i did these on my stocker i was well into 30psi.. gauge max.. and it never tapered back into range...
add a water/meth kit for cooling and upgraded intercooler and enjoy your new power...
