!!!Over Boosting Help!!!
Old Oct 16, 2004 | 10:51 AM
TonkaToy's Avatar
Ok,
Recently i just installed;
1.) Buschur Down Pipe
2.) Buschur off road pipe
3.) Buschur catback
4.) AEM Short Ram Intake
Ever since these mods my Greddy boost gage is recording 22-23.2 psi and this is NOT a SPIKE either its CONSISTENTLY around this psi , its starting to worry me a bit... as it make cause damage on my turbo...like blow my turbo or something......Looking for inputs;
1.) Is this a potential problem??
2.) what might be causing this???
3.) the best way to fix this...boost controller, aftermarket BOV, aftermarket MAS????
Thx
Old Oct 16, 2004 | 10:59 AM
TD05HR's Avatar
w. the mods u listen...its normal for the boost to go over alittle bit...from what u say it seems about right...so to answer ur questions...
1.theres no problems...u free up the exh. system and the psi goes up a little...
2.see answer in #1
3. boost controller should do it...manual or electronic one...
i dont understand why u bough all that stuff but not a boost controller...?
Old Oct 16, 2004 | 11:01 AM
4Gsixty3's Avatar
this is normal if u open up the exhaust and intake. u need to get a boost controller to down the boost a little.
Old Oct 16, 2004 | 03:36 PM
bo0oost's Avatar
I guarantee you it's your POS AEM intake. Take it off, and problem solved. I had the same thing.
Old Oct 16, 2004 | 03:47 PM
GPTourer's Avatar
Your BCS is being overwhelmed because your TBE has a lot less backpressure that it and the wastegate can handle. A BC will probably cure your problem.
Old Oct 16, 2004 | 03:56 PM
evo81's Avatar
you need an boost controller so you can get it to where you want.should've been one of the first mods you do
Old Oct 16, 2004 | 07:37 PM
4Gsixty3's Avatar
The AEM intake works fine for me so far... no problem. i m just curious what makes u say that?
3gEclipseTurbo
Feb 21, 2016 03:39 PM
Mellon Racing
Feb 1, 2012 10:44 AM
metalsaber
Apr 5, 2010 03:43 PM
Evil_1
Midwest Region
Nov 9, 2005 10:25 AM
SpyderBite
Oct 15, 2005 10:52 PM
