18k Mile Maintenance on EVO
I have done regular oil changes and I changed the plugs at 15k. I really haven't done anything else to maintain the EVO. I just hit 18k and I think I need to do driveline fluids. Any other things I should do? Any recommendations for what fluid to use?
Thanks.
Joe
Thanks.
Joe
Originally Posted by 2GDSM
Simple suggestion...if you own the car, they gave you the maintence manual...Try looking there
i can look there all I want...the first time I did it said to change my oil at 7500k miles....I said WTF? I don't trust the manual because it is wrong. I would like to go off what other people have done.
If you just drive normal i.e. 7/10 and ,maybe 10/10 a couple of times a week, I would change around 45,000. If you race a lot on tracks, or drag race a lot then maybe cut it to about 24,000 miles. Drag racing is what really stresses the fluids in the diff, and road racing heats up the tranny., so if you go to the track only like twice a year, just stick to 45,000.
just check the fluid first, look at the color, and see if fluid dirty, or has that "burnt" smell, or if there is any metal.i'm pretty sure evo has synthetic tranny fluid. Mosts manual transmisions don't fail cause of fluid though, it's not as important as with an automatic which also has to deal w/ tourque converter adding heat. But only you will really know if it needs the change.
zmeli is the man.
Originally Posted by Joe's_EVO8
i guess I feel like the car deserves something! So i thought it would need a little maintaining because I have owned it just over a year!
Transmission Fluid
GM Part #: 12346190 which is Castrol Syntorq LT 75W-85 GL-4
Engine Oil
76 Pure Synthetic 5W-40
Transfer Case and Differential Fluids
Dia Queen LSD 90WT which can be purchased from Mitsu parts. If the Parts Department has no idea what you're talking about, ask another employee or the manager. If those guys have no clue what you're talking about, they should find a new job and you should search for it online or go to another dealership.
Stock Oil Filter's do the job just fine.
I got that down about right, right Rick? Am I missing anything? Thanks again for this info. My EVO's gonna live longer than I am.
-Robert
