when do you DYI
Old Nov 4, 2004 | 10:24 AM
plokivos's Avatar
when do you DYI
when you DYI, how do you lift you car? on a jack or a lift? I wanna do my oil change, but I don't see how I could prop the car up.
thanks.
Old Nov 4, 2004 | 10:25 AM
Kwman's Avatar
hehe...friend of mine with an STi just drives one side on the curb and rolls under it...lol.
mifesto's Avatar
easiest/cheapest/safest way is to drive up a ramp... lift isnt exactly the safest but its doable too.... lift is the best if ur rich or have access to one
Old Nov 4, 2004 | 10:27 AM
rExTuHfEr's Avatar
i use two big jacks.....one on each side of the fron of car with stoppers behind rear wheels.....works fine for me.....ta rotate tires....two jacks on one side of the car.....pita but hey...it works...
Old Nov 4, 2004 | 10:28 AM
Enyth's Avatar
when i first read the title, at first i thought it said, "when do you DUI?"
Old Nov 4, 2004 | 10:32 AM
siantjab's Avatar
I got a set of Rhino Ramps for just that purpose. I used to jack up the passenger side and use a jackstand, but this is much easier. Simply drive up, do your work, then back down. Easy and cheap (under $30).
Old Nov 4, 2004 | 10:37 AM
kdogg's Avatar
Rhino ramps for me too. FYI, they sell a passenger car rated ramps for only $20.
Old Nov 4, 2004 | 10:38 AM
whitet777's Avatar
Just a word of warning about Rhino Ramps... They won't fit under a lowered EVO. Mine is lowered with the Tanabe GF210's, and the ramps weren't even close to fitting under the front bumper. I had to make my own ramps out of 2X10's.
Old Nov 4, 2004 | 10:40 AM
Scooter's Avatar
Ditto. Rhino Ramps for me too...
BTW don't you mean D-I-Y??? Do - It - Yourself.
Old Nov 4, 2004 | 10:43 AM
evoego's Avatar
Registered User
Rhinos here too...
Old Nov 4, 2004 | 10:59 AM
plokivos's Avatar
got a site?
Old Nov 4, 2004 | 11:02 AM
plokivos's Avatar
Old Nov 4, 2004 | 01:17 PM
Evolboost's Avatar
I do it all the time. Just drink a couple of 40's and do some dougnuts in front of the cop station.
I use Rhino ramps on my oil changes.
Old Nov 4, 2004 | 01:30 PM
wheredafucrwe's Avatar
i just jack my car up and then sit it on axel stands......
Old Nov 4, 2004 | 01:45 PM
dohcvtec's Avatar
i use a cheapo hydrolic jack and jack stands. for the front i place the jack at the center crossmemeber under the engine, then place the stands on each side behind the front wheels where you would normally use the cheapo jack for changing tires. for the rear, i jack up at the rear diff then place the stands right in front of the rear wheels on each side where you also would use the cheapo jack to jack up the car. when i say cheapo jack i mean the one that comes with the car also note, the front center spot where i jack the front up is not quite center, its a little more on the drivers side. but center enough to get it high enough to place the jackstands where they need to go.
