Necessary to have new injectors Machined and Flow Matched?
Old Nov 8, 2004 | 07:03 AM
EvoRs's Avatar
IM looking to upgrade my injectors, and im curious if its necessary to have them flow matched and/or machined first before installing them? Should they flow evenly when just buying them from a vendor or do I need to prep them in some way?
Old Nov 8, 2004 | 07:09 AM
2GDSM's Avatar
when you buy injectors from a company, they should already be flow matched and impedence matched...All you should have to do its take off the fuel rail and pop em in... That's how ive been doing it at least on 2G's.
Old Nov 8, 2004 | 07:22 AM
EvoRs's Avatar
Do i need to disconnect the fuel pump and any fuses to crank the fuel out of the rail before replacement? And what is the point of one getting say 650cc injectors machined and flowmatched to begin with like i have seen..
Old Nov 8, 2004 | 07:32 AM
2GDSM's Avatar
I am not sure about disconnecting the fuel pump on an Evo...on my 2G, i just disconnected the battery. I'll let someone else take over your question that would know better than I do. The point of having the injectors machined is so they fit in the rail properly without leaking or anything else. Flowmatching is obvious, if each injector flows differently then problems could arise with some cylinders being lean/rich etc.
Old Nov 8, 2004 | 07:54 AM
EvoRs's Avatar
Yea my stock injectors leak.. so id very much like to find a set that wont..
Old Nov 8, 2004 | 10:29 AM
Karash's Avatar
Sorry for the newb question, but do you have to anything to the ECU and/or Standalone (if you have one) if you upgrade to larger injectors?
Old Nov 8, 2004 | 11:41 AM
EvoRs's Avatar
Yes.. if u upgrade you need some sort of management to compensate, can be done with a simple flash as well..
