My Clutch Install Story w/ pics
Old Nov 10, 2004 | 12:27 PM
  #121
twinevo's Avatar
Originally Posted by Talon16G
<Note to self> If I see a silver EVO for sale from Merced, run...
or if you see one on Ebay
Old Nov 10, 2004 | 12:49 PM
  #122
Evo_toy's Avatar
f.u.c.k him by the trany dude
Old Nov 10, 2004 | 01:20 PM
  #123
reefro's Avatar
wow... sounds like what i was possibly about to go through as well... i have a friend who is a pretty good mechanic in my eyes, but as i read this horror story i could totally picture the exact same thing happening to me! looks like i will be saving up ~500 for the install now cuz i think im too scared to attempt this on our own...
Old Nov 10, 2004 | 01:28 PM
  #124
godai's Avatar
Originally Posted by wrcevo
^^ Exactly!! The mitsubishi wrc mechanics just take bout 10 mins...all they need is just to get under the car!! The engine does'nt need to be removed!!
ah.. and wrc cars are nothing like the street cars other than similar exterior.. rally cars are made to be serviced quick.
Old Nov 10, 2004 | 01:58 PM
  #125
ShapeGSX's Avatar
You know you have to get the clutch plate seated down on the flywheel completely before torquing it down, right? Otherwise, that 13 ft-lbs won't even get the clutch fingers compressed.
Old Nov 10, 2004 | 02:59 PM
  #126
twinevo's Avatar
i'll be babying my clutch from now on and saving up the $500 for when i need to take in to a PROFESSIONAL.
Old Nov 10, 2004 | 06:43 PM
  #127
RalliArtEvoVIII's Avatar
ok for all those who were in doubt of it...its done and it runs fine. Only problem i have is the reverse light wont come on when in R...the temp is all the way down in C i guess cuz the coolant hasnt flowed throughout the engine yet? had to bleed the clutch...i cant feel the pull that well, might be loose throttle cable, i think tires are a lil deflated from sittin around and umm...needs a wash desperately inside n out. No SES light so thats always a great thing. Thanks to the few of you that helped out!
Old Nov 10, 2004 | 06:54 PM
  #128
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
good to hear bro!
Old Nov 10, 2004 | 06:57 PM
  #129
thx!
Old Nov 10, 2004 | 07:18 PM
  #130
marksae's Avatar
Check the wire that runs to the reverse light switch. Also check the wire that runs to the coolant temperature sensor. They're probably not connected. Good to hear you got that thing running!
Old Nov 10, 2004 | 07:42 PM
  #131
johny719's Avatar
dude i'm sorry that happened... i was planning on doing the clutch myself... now i have 2nd thoughts
Old Nov 10, 2004 | 08:33 PM
  #132
where are the reverse lamp wires and the coolant temp wires??
Old Nov 10, 2004 | 08:37 PM
  #133
i, once again thank EvoM members for helping me out in my time of need. IF it wasnt for this site, i'm more than sure this car wouldnt be running right now. If my Throttle cable isnt the cause of me not being able to feel the "pull" around 3500rpm, what else would it be? Cuz when i take off i kinda give it a lil punch to about 3000rpm to see if it pulls hard like before, but it doesnt. No G forces felt. What could be the cause besides maybe a loose throttle cable? BTW, the clutch feels WAY diff, i actually stalled! I let off the clutch about 1.5 inches and boom shut off i was like whoa! Before, wit my old clutch that i was used to, i could let off about 4 inches and then start givin it some gas. Feels different but great. Just wanna get to the problem of why im not feeling the pull i should in a evo wit a brand new clutch.
Old Nov 10, 2004 | 09:01 PM
  #134
marksae's Avatar
Reverse light switch is circled in red:
#9 is the water temp switch:
Attached Thumbnails My Clutch Install Story w/ pics-water-temp_switch.jpg   My Clutch Install Story w/ pics-reverse_switch.jpg
Old Nov 10, 2004 | 09:12 PM
  #135
this helps... where does each of the plugs start from? liek the reverse light switch, i know where it goes, but where does the line start? same with the temp, thx for the pics btw it helps a lot
