Performance forecast
Old Nov 11, 2004 | 02:30 PM
k270kmh's Avatar
My car has 276 crank Hp (stock) and Car and Driver magazine post these numbers:
0-60 = 5 seconds
1/4 mile = 13,6/102
Top speed = 157mph
Now Let's assume that my car after some mods is doing 360-370 crank hp,
How would change the performance numbers? ? ?
I guess:
0-60 = 4,5 seconds
1/4 mile = 13/107mph
top speed = 165 mph
Are these numbers correct?
Old Nov 11, 2004 | 02:34 PM
gtr's Avatar
gtr
It'll run 12's with over 300 wheel hp on a dynojet
Old Nov 11, 2004 | 02:37 PM
k270kmh's Avatar
low mid or high 12 with 300WHP?
Old Nov 11, 2004 | 02:57 PM
EVOTEXAS's Avatar
360AWHP you are looking at a low 12 at 110+ or possibly a very high 11 if your launch is perfect, shifting is perfect and your clutch holds well.
Old Nov 11, 2004 | 03:03 PM
inariv5573's Avatar
Those forecast numbers are more for a stock Evo, except the top speed. But the 4.5, and 13.0 are pretty much stock.
Old Nov 11, 2004 | 03:32 PM
k270kmh's Avatar
360 crank hp let's say 310WHP!
Old Nov 11, 2004 | 04:06 PM
blackevoVII's Avatar
0-60 = 5 seconds
1/4 mile = 13,6/102
Top speed = 157mph
I guess:
0-60 = 4,5 seconds
top speed = 165 mph
ideally?
Low 4s
mid high to high 12s.
Top speed? your guess is as good as mine.
Old Nov 11, 2004 | 08:04 PM
EVOTEXAS's Avatar
Top speed is not going to increase very much.
Old Nov 11, 2004 | 08:11 PM
EV0lut10n_8's Avatar
top speed is drag land gearing limited...won't really change
Old Nov 11, 2004 | 10:55 PM
Ludikraut's Avatar
Modded Evo with cams should clear 170mph easily... just gotta remove the factory limiter.
l8r)
Old Nov 11, 2004 | 11:28 PM
newcar168's Avatar
i think no matter how much you modify the car, the top speed will not change by much. because when you reach certain speed the gear ratio still not change, modifying the engine will help you reach that speed faster but it wont increase the top speed. top speed all have to do with the gear ratio
Old Nov 12, 2004 | 04:34 AM
k270kmh's Avatar
top speed is 7500rpm, just cancel the rev limiter and go to 8500rpm!!! I don't how much spped you increase with 1000rpm in 5th gear but for sure 10mph.
Old Nov 12, 2004 | 06:42 AM
EVOTEXAS's Avatar
You should PM ASTROEVO. He says he has hit 191 at like 8600 RPMs.
