your thoughts on the mini battery?
Old Dec 1, 2004 | 08:16 AM
Derek888's Avatar
Originally Posted by ODB4G63
I have the 680 oddesy and an upgraded stereo with no problems. Of course it is just 1 JL amp and a JL10 w6 speaker so nothing too crazy but anyway no problems here!
how many watts?
Old Dec 1, 2004 | 08:40 AM
ODB4G63's Avatar
Well that is not really relevant because lots of amp manufacturers claim crazy wattages that they will never reach. I have seen some "1000 watt" amps that wont even push 200 continuous watts. But if you are familiar with JL's mono block 500/1 amp then that is what I am running....500 W RMS @ 1.5 ohm-4 ohm (11V-14.5V).
Old Dec 1, 2004 | 08:59 AM
sleet's Avatar
How many people have the buschur mini battery kit? I've been looking to buy this so I can do their upper ic piping aswell.
Old Dec 1, 2004 | 09:07 AM
ODB4G63's Avatar
There is an evom member that I got a Mini Battery tray from and then got the battery off ebay. I have about $145 in the whole set up. I believe the thread was titles "Guaging interest for mini battery" and the battery used is a Oddesy 680 with auto terminals. Exact same setup as Buschur for a fraction of the price!
Old Jan 7, 2005 | 02:00 PM
Ev0ikon's Avatar
I got the mini bat kit from Buschur and is now (getting cold) starting to have charging problem. I don't even run stock radio that often. Last few weeks I have to use my portable booster battery.
Old Jan 7, 2005 | 02:15 PM
Whoosh's Avatar
I've got one and love it. Never had any starting problems. I think it looks better in the engine bay, frees up room for a catch can and allows for the use of the BR upper I/C pipe. Plus it weighs so much less.
Old Jan 7, 2005 | 07:05 PM
Derek888's Avatar
you guys think this battery will work for daily use? 12V and 22Ah?
http://tw.page.bid.yahoo.com/tw/auct...aucview=search
Old Jan 7, 2005 | 07:18 PM
Kyle R's Avatar
I did a bunch of research on this for my S4 and ran a Genesis G16EP, cost about $90 shipped to my door and weighs about 12.5 pounds. On the S4 it was a weight savings of close to 30 pounds, or roughly that of a CF hood.
Pros:
Extremely-low internal resistance
Fast current flow
Easy starting
Vibration proof
Maintenance free
Will not develop a memory
Dry cell, so no liquid or gel (no acid to leak out)
Corrosion resistant terminals
Recharges quickly
Excellent storage life
Cons:
Life expectancy goes down significantly with heat
Must keep properly charged
http://www.stealth316.com/2-dynabatt.htm
A good link for information regarding sealed lead acid batteries
http://www.gotbatteries.com
Search for G16EP
or
Hawker Odyssey
Old Jan 7, 2005 | 08:38 PM
RyanM's Avatar
The Oddesy is an outstanding battery, and for its size puts out respectable CCA. Now running the stereo with the car off for a long period of time would be a bad idea. There are basically two ratings when you look at a battery, Cold Cranking Amps and AH. The Odyssey 680 is 680CCA. I don't know what the Odyssey AH is, but I'm sure its less than the stock battery. This is one of those size really does matter situations. I believe the stock battery is 500CCA.
Here's a link to everything you ever wanted to know about batteries
http://www.uuhome.de/william.darden/carfaq7.htm
Old Jan 8, 2005 | 11:30 AM
PTevo's Avatar
I have the bushchur mini battery, and just came back after 3 1/2 weeks vacation and no starting problems. BTW I live in Florida.
Old Jan 8, 2005 | 11:57 AM
justchil's Avatar
I got the Odyssey 680MJ.. It has a metal jacket that will prolong the life through extreme conditions. I haven't had any trouble with mine yet.. stock radio.
Old Jan 8, 2005 | 12:01 PM
Rollaway's Avatar
Had the same oddesy 680 on 2 different cars and not one problem.. even started my car up after 3 weeks of not driving
Old Jan 8, 2005 | 12:03 PM
mrmefodman's Avatar
Originally Posted by plokivos
so, what do you need to relocate the battery to the back?
Bad Idea, I read in a couple of mags that you would end up adding more weight in cabling to reach the trunk than u would save with smaller battery. Kinda self defeating
Old Jan 8, 2005 | 07:17 PM
gunzo's Avatar
Odyssey battery lasted around 2.5 years for me before dying .. pretty good compared to a standard SLA battery .. Got my replacement from www.portablepower.com for $80 shipped .. not a bad price .. I used back the standard battery tray, cut a slot at one end, and you can fit the battery lengthwise onto the tray .. drill a hole near the batt, and use back the battery hook (diy tiedown $3) viola! all done for less than $100 think it's in the how to sections ..
Odyssey specs .. www.odysseybatteries.com
I tested the batt at 345CA 12.7V
and it lasted around 25mins with radio on car not running
Old Jan 10, 2005 | 12:55 AM
Greyfox5's Avatar
I dont have one, but i intend on getting one. No I'm not going to be in the cold like u guys but from what i heard they are almost the same as a regular battery, just smaller. Plus there right u really only use the battery when starting the alternator dose most of the work, that is unless u got a mega sound system.
