Modifying a stock EvoVIII
Old Nov 24, 2004 | 11:54 AM
dhatzopoulos's Avatar
When you begin to modify, where is the best place to start? Which intake is the best for the Evo?
Old Nov 24, 2004 | 11:58 AM
Evo Police's Avatar
Im pretty much a NooB myself, so basically just use the SEARCH button. Don't waste a thread on something that has been covered many times!!
Old Nov 24, 2004 | 11:59 AM
fborg's Avatar
The best place to start is here
And here
Old Nov 24, 2004 | 12:13 PM
bluebanana23's Avatar
basic bolt ons should satisfy you for a while atleast. I suggest start with 3 inch turboback exhaust, MBC, boost gauge and a ecu flash. Cams are also a good bang for the buck. Like the other guys said the search button is your friend
Old Nov 24, 2004 | 12:15 PM
plokivos's Avatar
exhaust first, if you do it right, you'll drop a second off of your time, if you know how to drive.
Old Nov 24, 2004 | 12:33 PM
evolved04's Avatar
the intake seems to be a waste unless you are looking for the sound. turbo back exhaust is the big one that comes to mind.
Old Nov 24, 2004 | 01:34 PM
Racer RS X's Avatar
I did a dynoflash and manual boost controller first. Fairly inexpensive, and gives good results. The exhaust helps a lot.
As for conical intakes, I tried two different ones, and they did not help.
Good Luck
