Trouble Getting Lugs off
Old Nov 30, 2004 | 12:27 PM
RalliArtEvoVIII's Avatar
Whats the easiest way to take lugs off if theyre not coming off? On there TIGHT.
Old Nov 30, 2004 | 12:28 PM
siantjab's Avatar
Use a breaker bar.. Leverage is key!
Old Nov 30, 2004 | 12:31 PM
andyjd's Avatar
and use and eight sided socket...not one of the miltipoint contact ones...
hope that makes sense
Andy
Old Nov 30, 2004 | 12:32 PM
gtr's Avatar
gtr
Get a gorilla bar from Murry's or something. You barily have to pull and it breaks free
Old Nov 30, 2004 | 12:42 PM
justchil's Avatar
I just use a bigass 3/4 or 1/2 socket wrench
Make sure you torque them back properly.. as it can cause warped rotors
Old Nov 30, 2004 | 01:10 PM
thanks...btw: thx justchill for that psi to bar converter link.
Old Nov 30, 2004 | 01:42 PM
justchil's Avatar
hehe np man.. it's always there to help whomever
Old Nov 30, 2004 | 09:19 PM
Jakeg97's Avatar
jump on the stock lug remover tool
Old Nov 30, 2004 | 09:52 PM
marksae's Avatar
Andy
I think you mean use a 6-pt socket instead of the 12-pt ones. Whenever using a breaker bar to crack loose stuck nuts/bolts, ALWAYS use 6-pt sockets!
And as someone mentioned above, leverage is the key. A breaker bar should be more than adequate to crack stuck lug nuts loose. If that doesn't work, stick a long pipe at the end of your breaker bar and give it all you got!
BTW, how tight do you tighten your lugnuts? Spec is 73 ft-lbs +/- 7. I never have any problems cracking mine loose.
Old Dec 3, 2004 | 08:27 PM
well i could get a lug off easily with a long pipe for more torque, but the problem now is (i have gorilla lock nuts) 2 of them are sorta stripped. i've heard of welding a socket onto the tip and then taking it off, any other "home made" ways to take it off???
Old Dec 3, 2004 | 09:20 PM
justchil's Avatar
If you can take a pic of the lug nut I can help you out...
Do you have a dremel tool and or air impact wrench?
Old Dec 3, 2004 | 09:23 PM
plokivos's Avatar
sears.
Go get one of those "I strip my bolts, I need help" wrenches.
Old Dec 3, 2004 | 09:24 PM
LancerOZ's Avatar
If you are using the stock tool provided by mitsubishi..... just stand on it. Place the tool in the proper position over the lug and jump up and down on the handle... it WILL come off. I had the same problem.
- Jason
Old Dec 3, 2004 | 09:29 PM
justchil's Avatar
lol I've seen little "kits" for stuff like that...
I still say the dremel is your friend.. I've got a diamond/carbon bit that was around 15-20 bucks.. it will cut ANYTHING.
Originally Posted by plokivos
sears.
