Boost Wiggle?
Old Dec 3, 2004 | 03:04 PM
avengerhed's Avatar
Boost Wiggle?
On the highway today, cruising in 5th I smoothly worked the Evo up to WOT. Boost climbed and held steady at 19lbs, higher than I am used to seeing in 5th at WOT but it was pretty chilly here (35 F). After coasting back down to about 65, I downshifted to forth and went to WOT, boost climbed to 19 lbs and then wildly fluctuated from 19 to 15 lbs and back. I retried 5th gear (19 lbs steady) and then retried 4th (19-15 fluctuating).
Is this normal? My two possible thoughts were a leaky BOV (stock) or the wastegate activation.
I have a Defi D-series gauge that has never acted up before, and I am tapped into the vac line running between the intake manifold and the FPR.
any ideas?
thanks
Old Dec 3, 2004 | 03:15 PM
mifesto's Avatar
im also thinking the cold weather made your boost spike... you didnt mention if you had stock or aftermarket boost controller.....
Old Dec 3, 2004 | 03:27 PM
avengerhed's Avatar
engine wise the car is stock
stock BC, stock BOV, stock intake, stock exhaust
Old Dec 3, 2004 | 07:21 PM
05-EVO-GSR's Avatar
any ideas?
thanks
You beat me to the post for the very same question! Mine does the same thing. I spike to 22 then fall back to 20 then 17.5. Sometimes it wiggles between 15 and 17, sometimes it is rock solid. I just installed the 42 Draft gauge kit with boost, Oil PSI and Oil Temp.
BTW: Do you get 19 on the vaccuum side for idle?
Old Dec 3, 2004 | 08:39 PM
avengerhed's Avatar
i do occasionally get 19 on the vac side, but usually its 16-17 inHg
Old Dec 3, 2004 | 10:42 PM
kataklyzm's Avatar
if its stock the evo boosts up to 19.5 and drops back to 16. if its constantly boosting 19 and staying there, consider yourself lucky!
Old Dec 3, 2004 | 11:04 PM
plokivos's Avatar
yes i feel lucky.
But here is the thing about boost fluctuation. It's there so the car wont lean out too much, I think.
If you know how to modulate the accelerator just right, then the boost will stay at 19.5psi until the redline.
Trust me, I do this all the time without MR BOV or Boost controller.
Old Dec 3, 2004 | 11:08 PM
platinumspecv's Avatar
get a MBC it'll feel even betta!!
Old Dec 4, 2004 | 11:46 AM
05-EVO-GSR's Avatar
my boost holds at 19.5 psi without MBC/MR BOV- sweet~
Yeah, mine will do the same if you hold the gas pedal half way. If you floor it, it spikes then pulls back.
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
MRLancer05
Jul 27, 2016 03:52 PM
DrEvo
36
Sep 15, 2004 06:23 PM
TheeVOoNE
10
Apr 8, 2004 05:07 PM
sir lurks alot
Nov 6, 2003 06:26 AM
