24 hours from hell
Old Dec 4, 2004 | 08:36 PM
Jakeg97's Avatar
good luck trying to get all that done in one day
Old Dec 4, 2004 | 09:42 PM
mo168's Avatar
Becareful Man
BECAREFUL MAN.. don't get under the car when the jack falls...
SCARELY!
Old Dec 4, 2004 | 10:46 PM
mrdci's Avatar
Never do any serious work with the factory jack. Best thing to do is get an aftermarket small one that is rated for more weight. Another helpful tip is if your tire is completely flat if you can find a nice size rock or something else close by stick it infront of the tire then pull up until the flat is on top of it. Its less height you'll have to actually jack the car. The once the wheel is off just remove and put on the donut. Used this alot offroad
Old Dec 4, 2004 | 10:56 PM
davyper's Avatar
be carefull next time man. glad your ok.
Old Dec 4, 2004 | 11:08 PM
KillaSweep's Avatar
anyone know where to get a good floor jack that fits under a very low Evo....or any low car for that matter? I can;t fit my hydraulic floor jack under my car right now.
Old Dec 5, 2004 | 07:32 AM
night_wing's Avatar
10min evo owner
heres a pic of wat she hit but i didn't take a pic from the back
Old Dec 5, 2004 | 08:14 AM
nothere's Avatar
hey a little JB Weld and that wheel is as good as new.
killasweep, drive up on a couple of flat 2x8s before you try the floor jack.
hey guys, floor jacks are cheap, they are the only way to lift a car. ramps are good too.
on the other hand if your garage has high ceilings get a lift, they are only about 2k.
Old Dec 5, 2004 | 08:23 AM
OZLancerlunatic's Avatar
scary thing, my mitsubishi jack collapsed also........thats some scary stuff seeing the car come down, thank god it wsa when i was putting the jack stand in, it fell onto the jackstand.
the jack is totally bent, first time using it and it collapsed under the weight.......
anyone think there might be a problem with the jacks being week? since then i have invested in an high quality jack
Old Dec 5, 2004 | 11:37 AM
evolved04's Avatar
^^ duct tape might fix that. you could roll it up really tight and then......nevermind. sorry about your car. good luck getting it fixed.
Old Dec 5, 2004 | 11:38 AM
05-EVO-GSR's Avatar
When your car is done, have the alignment checked.
Old Dec 5, 2004 | 12:07 PM
tke_413's Avatar
I'd be SHOCKED if the alignment wasn't screwed up after hearing it hit the curb and lift the left side of my car off the ground.
Old Dec 8, 2004 | 08:55 PM
tke_413's Avatar
Just a little update
The ventvisors, vortex generator, helix cat-back, and slotted rear rotors have come in so far. Tomarrow the downpipe, high-flow cat, rim, and walbro fuel pump should (BETTER) be coming in! Parts are starting to pile up in my room and Friday's starting to look like it's going to be LONG.
Old Dec 9, 2004 | 11:27 AM
EVOLust's Avatar
I am surprised that noone near you is willing to try and help since it seems to be a great challenge. If you pull it off, you will feel like a god afterwards. Good luck.
Old Dec 9, 2004 | 11:31 AM
TRDHarrier's Avatar
i remembered that I forgot to use a wheel chock and my car rolled back and landed right on top of my jack stand, tipped over my jack, and i cracked my sideskirt. Nothing major. Cant see it. But I could hear it when my tires rub on it now. Doesnt really matter tho. Couldve been worse.
Old Dec 9, 2004 | 11:36 AM
tke_413's Avatar
Woohoo! Well, I got one thing installed so far...the shorty antenna!!!!
Shorty Antenna - DONE
Vortex Generator
Ventvisors
Rim mounted on tire
Rotors
Downpipe
High-flow cat
Cat-back
Fuel pump
TurboTrix flash & Tune
Baby steps, baby steps.
