Just got new EVO. Some feelings and lots of questions.
Old Jan 1, 2005 | 08:50 PM
  #31
Jhodel's Avatar
I don't understand why some of you feel compelled to mess with the oil. Seriously, you are just asking for trouble. Run the oil that came in it and get the oil changed at the recommended interval just like the manufacturer recommneds - 3000 miles according to my dealer. Everything will be fine - and if it's not, it'll be covered by warranty. Otherwise, the dealer will say that you have screwed around with the car (which you have) and can deny any warranty cliams
As far as the S2K goes, if I was looking for a rear wheel drive two seat convertable I would have looked at one.....
Jim
Old Jan 1, 2005 | 09:02 PM
  #32
Jakeg97's Avatar
hello and welcome
Old Jan 2, 2005 | 11:29 AM
  #33
marksae's Avatar
Werd.
Old Jan 2, 2005 | 11:39 AM
  #34
KazzEvo8's Avatar
Originally Posted by bluedd
Thanks Kazz. Any recommendation on synchromesh brand? I'll do a search on actual numbers in camber.
Autozone carries it...
Old Jan 2, 2005 | 11:45 AM
  #35
donutmonkey's Avatar
Autozone! Now there's quality...
Stay with what the manual, and the engineers who designed and built the car, spec out for the trans, transfer case, lsd, and engine. If something breaks, then it's on their dime - not yours.
Old Jan 2, 2005 | 12:16 PM
  #36
bonestockevo8's Avatar
Actually autozone carrys Mobil 1 and other "spec" fluids, so I wouldn't be so quick to knock em. But I do agree about staying w/ the same brands as recommended by mitsu.
Old Jan 2, 2005 | 04:13 PM
  #37
05-EVO-GSR's Avatar
You might want to mod your PC first so you can use the search function. Plenty of people have been down this road and you can learn alot from them.
Old Jan 2, 2005 | 04:30 PM
  #38
Richard EVO's Avatar
This is a reply to the original post. Since you got an '04 VIII, you did not get the front limited slip differential that I got on my '04 RS, and that comes on all '05 EVO models. I would suggest you invest in a front LSD. That will solve the steering problem you complain about. My RS has incredibly precise steering.
As for mods, mine were all done by John Mueller and his team at Road Race Engineering in Santa Fe Springs, Calif. I have cams, upgraded intercooler, airflow controller, bigger fuel injectors, fuel pump, gauges to monitor air/fuel ratio and exhaust temperature, manual boost controller, head studs, intake, titanium exhaust, rally cat, 3" downpipe, coil overs, rear swaybar, and 4-point harness.
To use a phrase, it HAULS ***!!!
Old Jan 2, 2005 | 04:38 PM
  #39
Az3ar's Avatar
Originally Posted by pharmd98
Congrats on the new evo. You should give it more time to get used to the car. 1) Is there any other engine mods that you would recommend? How about just the dp with the stock exhaust?
Leave the engine and intake stock for now. I would start with a turboback exhuast after breaking in the engine using regular non-synthetic oil for the first couple of thousand miles then maybe move on to engine management.
2) Would this improve over time as the suspension is broken in?
you might want to check your tire pressure as evo is known as probably the sharpest handling compact car ever. The steering is faster than everything else out there and you should feel very connected to the road. Maybe give it more time.
Sorry can't help you on the rest.
You have to use synthetic oil on the EVO. these engines are broken in from the manufacture.
Old Jan 2, 2005 | 05:22 PM
  #40
UT_Evo's Avatar
The engine is NOT broken in from the factory, don't listen to anyone on here or anyone at the dealership, stick to your owners manual which specifically talks about the 500 mile break-in period, as well as the break-in for the clutch and the brakes...if you come to something the owners manual can't answer, then ask on here, definitly don't drive it hard for the first 500 miles, though.
Edit: Hell, don't even listen to me...you can't believe everything you read on the internet.
Old Jan 2, 2005 | 11:25 PM
  #41
bluedd's Avatar
After playing with the tire pressure, it's feeling much better now. The main reasons I went for 04 were huge discount, HID, and I don't think I need ACD. LSD is the only thing that might really matter (I suppose the 04 to 05 turbo changes won't even matter once I start adding some mods). Will definitely consider LSD when mod starts.
Great advice That's very true but this site and other sites, s2ki, vwvortex, do provide lots of valuable information for my cars. Can't live without internet these days.
