Fq 400
Old Jan 5, 2005 | 09:11 PM
Jakeg97's Avatar
you can , but lets be realistic
Old Jan 6, 2005 | 04:27 AM
ride22's Avatar
Originally Posted by EVO_JOE
Does this company have a bad reputation???
Do a search on this board and you will find many write ups, particularly one tha t I did. They don't have a bad rep if you like paying $30k for a car you will never receive, and if you ever do get it you won't be able to drive it on the street legally.
Maybe they have changed, but I doubt it.
Old Jan 6, 2005 | 07:48 AM
evolved04's Avatar
my freind in iraq who is in the army, was told that if he bought a car in europe (where he was stationed before he went to iraq) that when his contract was up, the army would ship a car for him overseas. he did the research, and found that even though the shipping cost would be nothing, it would be extremely expensive to get it stateside legal. so much of a hassle that it isnt even worth buying something that isnt already sold in america, even with FREE shipping.
Old Jan 6, 2005 | 10:07 AM
cecilia's Avatar
man, that sucks
Old Jan 6, 2005 | 10:11 AM
Remorseless's Avatar
Registered User
It would be cheaper to move to England. Also I think they are all sold at this point.
Old Jan 6, 2005 | 10:15 AM
Rollaway's Avatar
That thing costs $87,000.... You can buy a regular evo here and either replicate it for much less or build a better one.. the good thing about the FQ400 is that it has a warranty but only over there
Old Jan 6, 2005 | 11:01 AM
jotan82's Avatar
you can build your own FQ700 for less
Old Jan 6, 2005 | 11:18 AM
justchil's Avatar
Buschur stage 4/5 a lot cheaper.
Old Jan 6, 2005 | 12:54 PM
wrxIIevo's Avatar
not worth it, get an MR and throw another $10000 into it will probably give u something called FQ-500
Old Jan 6, 2005 | 06:06 PM
housedj's Avatar
here is what RC Developments (UK) says about the FQ series & why someone shouldn't buy 1. they are splicing in Unichip modules just so everyone knows:
www.rcdevelopments.com
FQ 340 findings
This information has been published to make owners and potential customers aware of our findings after tests were carried out by our technicians. These tests are routine tests done to all cars prior to modification, The car tested was a factory spec, 2004 Lancer MR FQ340.
What is an FQ
An FQ*** is a conversion done at the SVA test center in Southampton.It is not a Japanese model. In the case of this Lancer MR and others tested, Mitsubishi UK seem to have used a unichip system, which intercepts the signals from the air flow meter to control fuel and corrupts the signal from the crank angle sensor to adjust ignition timing. The major side effect of using this system is that the injector timing is delayed or advanced respectively. This then potentially results in incorrect injection timing compromising engine efficiency, fuel economy and performance.
Boost control ?
Click below to enlarge image.
The boost has been increased, as stated below. They appear to have used the existing boost control system which is stretched beyond its capabilities. It is not clear what target boost they wished to achieve due to the severe overswing and boost oscillation on all FQ340's we have tested.
Background
To extract 340 bhp from any Evolution model, with reliability, RC recommends that an after market ECU is used- not a piggy back unit that modifies the signal to the ECU - as is the case with the Unichi. An aftermarket ECU allows the ignition advance, injector timing, fuel and air mixture to be mapped to exact tolerances independently. RC also recommends an uprated boost controller which may or may not be part of the ECU. A quality item such as an Apexi AVCR would be a good choice. This is because it is capable of controlling the boost with such accuracy that avoids dreaded overboost. If uncontrolled overboost occurs, then an engine may start to detonate and this can melt a piston or breaks a con' rod, which then exits via the sump or engine block !!
Conclusion and test results
We attached a boost gauge to the MR along with our wideband lambda reader to see if all was well prior to working on the vehicle. We also took a stethoscope to listen for nasty noises - just incase.
When driving, we were disappointed to notice MASSIVE boost over-swing. Our gauge actually showed over 1.6 bar..... In fact the boost sent the needle off the gauge and then oscillated at around 1.4 bar. We would expect a max of 0.05 bar as an over-swing figure, not well over 0.2bar !
Next, as the revs climbed, we noticed that the car was running very lean. TOO lean to be safe. It was tuned like a NA car not a turbo ! We were concerned that this would causes detonation and unfortunately we were right. It was audible between 5500 -6000 rpm. and we lifted off the power instantly.
Summary
With the price of a Lancer MR FQ340 running at £5500-£6000 more than a standard MR, we would have expected a modified ECU at least, coupled with a quality boost controller. We would recommend that potential customers purchase a standard MR model and then they can be sure they are buying a genuine Japanese Mitsubishi. Unichips are not fitted to Evo's in Japan and tuning upgrades can be purchased at a later date when informed decisions have been made.
The Lancer MR is a very fine car and in our opinion, Mitsubishi have crafted an excellent vehicle which is certainly the most refined of the Evolution series. Features such as a Carbon Fibre roof section, twin boost solenoid, cast alloy recirc' valve and new turbo are all excellent performance/quality improvements on previous models. Cosmetically, the MR offers cool black light clusters with a smoke tint, all new cloth and alcantara seats with a black steering wheel centre boss, not to mention carbon fibre dash. The only negative comment we have, would be the choice of suspension setup, as the Bilsteins are some what crashy and induce a little too much body roll for our tastes.There are companies such as JIC and TEIN who are masters in this field, who we feel would offer improved road holding and comfort but also minimise body roll in a direct comparison.
RC
Old Jan 6, 2005 | 06:07 PM
housedj's Avatar
Talking
sorry everyone if the writing didn't come thru. if not go to the rc site, scroll about 1/2 way doen & click on the FQ 340 pic.
Old Jan 6, 2005 | 06:13 PM
RuEvolved's Avatar
Try MOTOREX but they usualy deal w/ skylines...again mucho moola.
Old Jan 6, 2005 | 06:14 PM
giumela's Avatar
So piggy back systems are not too reliable? Doesn't Vishnu make extrensive use of their piggy-back system? Is it because it's a cheaper way to mod your car?
Old Jan 6, 2005 | 06:21 PM
housedj's Avatar
piggybacks work fabulous. it's only the Unichip that sucks big booty. if you have watched the fq vs lambo video, the guy explains about retuning every 4k miles. a good piggyback system may need minor tweaks here & there but basically can be left alone.
Old Jan 6, 2005 | 09:32 PM
DoggieHowser's Avatar
While RC has been tuning Evos for a long time, they may not be aware that the stock JDM/UK spec MRs ARE ALREADY boosting at 1.6-1.8 bars without any boost controllers.
I doubt if the UniChip is doing anything significantly different from the stock ECU except maybe use a different fuel map to take advantage of the better breathing exhaust and intake.
Also, the FQ400 is quite different from the other FQs. It uses the Motec PnP ECU NOT the UniChip.
evobroker
Apr 14, 2016 07:22 PM
ArchieBabes
Dec 25, 2011 01:07 AM
frenchy99
Mar 14, 2006 03:17 PM
rcheung
Dec 29, 2005 08:22 AM
pjork-master
Sep 14, 2004 01:08 PM
