How much whp with these mods?
Im all stock, i need to know how much whp will i have if i put a MBC at 21 psi?
How much whp with MBC at 21 and a dyno flash?
How much whp with MBC at 21 and flash and 3" turbo back?
I need to know how much it will take to reach 300whp?
Thank,
Thank,
Visit the vendor forums and you'll see their staged upgrades or tunes. Each will probably have dyno charts and show u which mods made which. But for 300whp im sure 21psi, 3" turbo back and a custom reflash will get u close. With Cams you'll def be 300+whp.
Krunal
Krunal
To reach 300whp you will need turbo back exaust, dynoflash,boost controller, walbro fuel pump. That will do it. Probably have a little more than 300whp. MBC with boost controller set at 21psi and dynoflash,=280whp. will need at least K&N drop in and fuel pump. Any time you run more boost, be safe upgrade to walbro.
it all will depend on what dyno u use. i say run your car (AT A GOOD TRACK) & your time will determine your power. remember our cars are geared to go 157 so if you're scooting down the track even in the low 12's you're hauling...
then change your lic plate to VETTETR!!!!!!!!!!!!!!!!!!!!
Originally Posted by F&I-EVO
What would 300 whp give u in the 1/4 mile? With an excellent driver?
20.5 psi is what just my turbo-back is making me run on a cold day like today...tapers down to about 19.3 and MBC would get rid of a good deal of taper...or so I'm told, how long does it take to install one of the fuel pumps?
Originally Posted by sleet
If you want 300WHP then get 3" Turbo back Exhaust, intake, MBC, fuel pump, tune. Enjoy.
