Found BOV disconnected,
Old Jan 8, 2005 | 09:50 PM
herbal77's Avatar
I found my MR DV valve disconnected, and I think it was like that for a couple of days, I know that it can lean out because of unmeasured air, but is there someway I can check if something was damaged, or does anyone know the likeliness of me blowing my engine due to this.
Old Jan 8, 2005 | 10:01 PM
EVOTEXAS's Avatar
It's no big deal.
Old Jan 8, 2005 | 10:13 PM
herbal77's Avatar
you really think so
Old Jan 8, 2005 | 10:29 PM
Curt@MrLed's Avatar
Former Vendor
if its leaking itll make you run lean. if its disconnected youll get turbo backspool. u put it back on so you should be ok. if you want to be sure pull your intake and spin the impellar shaft putting presure on it and see if it binds. should spin free. but have a little play in the shaft
Old Jan 8, 2005 | 10:35 PM
feldguy's Avatar
um....what?
Old Jan 8, 2005 | 10:39 PM
Curt@MrLed's Avatar
Former Vendor
you said the bov was disconnected right. disconnected where ? vaccum line, off of intake, etc.
Old Jan 8, 2005 | 11:02 PM
90GSX-03EVO's Avatar
Originally Posted by feldguy
um....what?
Compressor Surge. Compressor surge is known to wreak havoc on a turbo, inducing shaft play.
Shaft play. If it is severe, it will not give a good seal and will end up leaking under high boost, or leaking oil or water into your exhaust track.
Old Jan 9, 2005 | 05:49 AM
SilverCOEvo's Avatar
I'd be curious to hear which part wasn't connected as well. Recirc part?
Old Jan 9, 2005 | 07:24 AM
sleet's Avatar
I'm sure you'll be fine, if you didn't notice it while driving when don't worry.
Old Jan 9, 2005 | 08:55 AM
herbal77's Avatar
the BOV had disconnected from the bottom , the intake part.
Old Jan 9, 2005 | 09:21 AM
chinto's Avatar
ya thats where it recirculates back into the intake no big deal. nothing was harmed. if any thing you ran rich each time u took ur foot off the gas.
that is how you get a VTA ( vent to air ) bov .
Old Jan 10, 2005 | 10:57 AM
herbal77's Avatar
would i be able to use any type of heater hose for the bov
Old Jan 10, 2005 | 11:01 AM
plokivos's Avatar
I don't think shaft plays gonna be there unless your boost surge was horrible.
I would check the turbo for the shaft play, just wiggle a bit to see it. I highly doubt that it's there on a fairely new turbo.
make sure that things connected securely.
