Evo VIII question
Old Dec 24, 2002 | 02:31 PM
Gareth's Avatar
Evo VIII question
I looked at the pictures in the 2 manuals and it looks like the Evo VIII and the US Evo are the same thing? Is that right or no? If they are different, what is different?
Old Dec 24, 2002 | 02:44 PM
gtr's Avatar
gtr
As rumors go:
JDM GSR
1. 6-speed,
2. 2 dins, "just look at the radio"
Headlights "look at the orange markers
3. ACD "Active center differential" ON dash they have 3 setting "snow, gravel ,tarmac"
4. AYC "Active yaw control" It's basically a dynamic limited slip diff to prevent loosing control from oversteer.
5. More hp. All japanese cars claim 276hp but the evo is actually 300+
6. Titanium turbo
7. under 3100lbs
8. Very skinny recarios with high boasters
9. evolution badge by shifter.
U.S. evo
1. 5-speed
2. 1 din and cheap radio.
3. Dot legal headlight.
4. No ACD and definitely no AYC
5. 271hp
6. Titanium turbo??????
7. under 3300lbs "with 5speed!!!!!!"
8. Wide recarios for us Americans take that how you want but those evo 7 seats are tight and i dont' know if i can put up with that.
Note: This is just on top of my head. Maybe more features?
Old Dec 24, 2002 | 03:44 PM
BurnOutz's Avatar
The USDM Evolution is built more for the American crowd. It needs to pass the regulations for crash tests AND also has about 1 ton of soundproofing. Whats next, 8 turns lock to lock steering and very soft springs for a nice ride?
Old Dec 24, 2002 | 04:41 PM
evo_dan's Avatar
I heard all the extra weight for the USDM Evo went into leaf springs.
Old Dec 24, 2002 | 05:47 PM
Yojimbo's Avatar
I thought we were getting US spec seat warmers and that's where the weight went?!?! Or maybe they put dual climate control in there? heh
Old Dec 24, 2002 | 06:00 PM
xcdan's Avatar
Or....... maybe they are smuggling people into the us via Evolutions, that weight is absurd.
Old Dec 25, 2002 | 01:07 AM
MaxR's Avatar
12345
Old Dec 25, 2002 | 01:36 AM
BurnOutz's Avatar
Originally posted by MaxR
is 3300 lbs right? thats a deal breaker in my book. the iron block was a real surprise, even the lowly wrx has an aluminum block.
Not to mention the weight ratio front to rear. I heard the VII had a very unbalanced 61:39 or something like that.
Old Dec 25, 2002 | 01:49 AM
evo_dan's Avatar
That doesn't mean anything, because the Evo VII's handling is neutral. This is what matters in the end and there are several ways in which it achieves this.
Old Dec 25, 2002 | 01:51 AM
BurnOutz's Avatar
That doesn't mean anything, because the Evo VII's handling is neutral. This is what matters in the end and there are several ways of doing this.
I always thought there was other factors though when it comes to this such as tire wear and brake fade.
Old Dec 25, 2002 | 02:01 AM
evo_dan's Avatar
You have a point there. I'm only refering to the aspect of handling in corners and how the weight can affect this, however from what I understand if the handling is neutral tire wear should be pretty even.
Old Dec 25, 2002 | 08:57 AM
Boosted's Avatar
wait now the EVO is comming with an iron block?????
Old Dec 25, 2002 | 10:35 AM
Gendo Ikari's Avatar
Actually...according to that brochure that Rax posted of the JDM Evo...it appears as though the AYC system has been revised and evolved into a "Super AYC".
Old Dec 25, 2002 | 05:58 PM
themi6group's Avatar
are you being sarcastic or are you serious? iron blocks are much stronger than aluminum for the extra heat generated by boost. iron blocks are a must.
Old Dec 25, 2002 | 06:15 PM
trigeek37's Avatar
iron blocks are prefered, but an iron sleeve can work too, but still not as good.
