MR 6 speed and 1/4 mile times
Old Jan 9, 2005 | 09:48 PM
MyCre8n=Evlshn's Avatar
Registered User
moved to 3rd page
Old Jan 9, 2005 | 09:49 PM
EVO_JOE's Avatar
the 6-speed tranny can't go 140MPH in forth gear you have to switch to 5th.
Old Jan 9, 2005 | 09:53 PM
SJ EVO 8's Avatar
Well the reason al traps 137 in fourth gear is mainly due to the fact that he can shift at 9,000 rpms.
Old Jan 9, 2005 | 09:54 PM
urbnprsutvhicle's Avatar
he wants to know with 6 sp trans what rpm in 4th @ 140 mph i think
Old Jan 9, 2005 | 10:00 PM
Rollaway's Avatar
on the 5spd.. my 03 evo ive hit 187mph gps confirmed and even hit 8600rpms in 5th which is 199mph theoretically.. but never had that confirmed...if you have enough power and with the gearing of the 5 speed its possible
Old Jan 9, 2005 | 10:05 PM
housedj's Avatar
Rollaway could be right. we would have to investigate Indy & F1 r&d to prove it. i think i remember reading about an Indy car having about 9k lbs of downforce at 180 & how much more power they would need to get the car over that speed. if the evo was shaped more like the Enzo, maybe we wouldn't need as much power...
Old Jan 9, 2005 | 10:14 PM
Registered User
moved this below
Old Jan 9, 2005 | 10:15 PM
EVOSTEVO's Avatar
hey so um...how bout those 1/4mi times? lol
5 speed ownz 6 speed
Old Jan 9, 2005 | 10:23 PM
UT_Evo's Avatar
Just as another thing about MR vs the other's, that weight that's shaved off the top..4kg or whatever, actually screws the handling a bit on the stock set-up...i watched a Japanese car video where they were testing it out, they drove the mr plain, and then put a big sheet on the roof of the car to simulate the 4kg and it was faster with the extra 4kg...maybe it's just a JDM Evo VIII thing, but still
Registered User
So what's the rpm of the six-speed tranny, staying in 4th gear and running a 140mph 1/4 mile? Who can calculate that?
I'm looking at the chart of RPM vs Speed of the two transmissions (attached). This chart, if I recall correctly, was made by one of our forum members, but it doesn't look accurate from what we're hearing from Al.
Can we just take the two gear ratios (the 4/5 and the 4/6) and do a proportionate comparison to get the answer?
Anyway, the chart's at the bottom (see thumbnail below)
And is a quote of gear ratios posted by "plokivos" Thanks plokivos:
evo 8 gear ratio
Gear Ratios
1: 2.928:1
2: 1.950:1
3: 1.407:1
4: 1.031:1
5: 0.720:1
Final drive: 4.529:1
Evo MR gear ratio
Type: 6-Speed Manual close-ratio
CVT Ratio: Not Available
1st Gear Ratio: 2.909:1
2nd Gear Ratio: 1.944:1
3rd Gear Ratio: 1.434:1
4th Gear Ratio: 1.100:1
5th Gear Ratio: 0.866:1
6th Gear Ratio: 0.693:1
2nd Reverse Ratio: 2.707:1
Final Drive Ratio: 4.583:1
__________________
Al, what's your RPM when you hit the quarter mile finish line? You're at 137mph in 4th gear running what rpm?
If someone can give some really accurate rpm at speed (of course we'll have to fudge and assume the same variance from stock in wheel circumference...so let's assume running the same wheels as whoever has hard data on their car),
then we should be able to calculate the rpm of the same trap speed in 4th gear on the MR by using:
1.031:1 = drive ratio of 4th on Evo8 5-speed (henceforth referred to as 4th/5)
1.100:1 = drive ratio of 4th on MR 6-speed (henceforth referred to as 4th/6)
RPM = rpm of 4th/5 at trap speed (Al's trap if we can get it...137mph)
thus (1.100/1.031) X RPM = rpm of 4th/6 at same trap speed in quarter mile
Attached Thumbnails MR 6 speed and 1/4 mile times-evo_5spd_vs_6spd_comparison.jpg
Old Jan 9, 2005 | 10:43 PM
Rollaway's Avatar
The Enzo actually sacrificed topspeed for more downforce.. like it matters for that car
Old Jan 9, 2005 | 10:46 PM
Rollaway's Avatar
I had a similar post to this when I hit 8600rpms in 5th Gear in my 03 Evo
Here are the Numbers for the 5 speed... sorry but i dont have it for 4th gear but you get the idea
Final Drive Ratio: 4.529
1st Gear 2.928
2nd Gear 1.95
3rd Gear 1.407
4th Gear 1.031
5th Gear 0.72
Here is the tire diameter for a 235/45/17 tire: Tire Diameter 25.32677
Here are the speeds in mph for fifth gear at each specific rpm:
rpm mph
6000 139.4
6100 141.8
6200 144.1
6300 146.4
6400 148.7
6500 151.0
6600 153.4
6700 155.7
6800 158.0
6900 160.3
7000 162.7
7100 165.0
7200 167.3
7300 169.6
7400 172.0
7500 174.3
7600 176.6
7700 178.9
7800 181.3
7900 183.6
8000 185.9
8100 188.2
8200 190.6
8300 192.9
8400 195.2
8500 197.5
8600 199.9
8700 202.2
8800 204.5
8900 206.8
9000 209.1
9100 211.5
9200 213.8
9300 216.1
9400 218.4
9500 220.8
Old Jan 10, 2005 | 05:50 PM
Fourdoor's Avatar
evo 8 gear ratio
Gear Ratios
1: 2.928:1
2: 1.950:1
3: 1.407:1
4: 1.031:1
5: 0.720:1
Evo MR gear ratio
__________________
Looks like it matches up darn close to what Big Al said to me, on the chart the 4th gear in the MR tops out at 113, Al said "around 110". Close enough for government work
Now, what would interest me would be putting the final drive gears from the 5 speed into the MR. That would give you higher speeds in each gear, and probably better 1/4 mile times than either of the other setups..... oh, and lower high speed cruising RPM's for better fuel economy as well
Keith
Old Jan 10, 2005 | 05:57 PM
plokivos's Avatar
Originally Posted by DynoFlash
My evo goes 140 mph in 4th and would prob go well over 190 in 5th (no I am not testing that theory) - I am not sure how much faster I would need to go ! The 6th gear is mostly for gas mileage and lowering noise on the highway
Boooo, test it like Top Secret Supra! Do the highway run 3 in the morning! lol
Old Jan 10, 2005 | 07:40 PM
DynoFlash's Avatar
140 mph in my evo = 8650 rpms in 4th - but with 255 40 17 tires
evo 8 gear ratio
Gear Ratios
1: 2.928:1
2: 1.950:1
3: 1.407:1
4: 1.031:1
5: 0.720:1
Evo MR gear ratio
__________________
