2005 evo 8 or 2005 STi
Old Jan 26, 2005 | 02:42 PM
BUFF BOY's Avatar
hi
just joined this forum because im in the process of buying a NEW evo 8 or 05STi but im not sure which is better.
iv posted on a wrx forum and asked most of them rekon evo 8 is pretty good too.
im more into the evo looks and performance aswell but i just need as much infor as posible before i throw 60 Gs away.
i really like the world rally blue STis with 6 gears and nice looking front end and all.
im from australia by the way.
so can someone tell me all the specs of the 2005 evo 8 ??
cheers
Old Jan 26, 2005 | 02:47 PM
Jakeg97's Avatar
get the mr if you can
http://www.mitsucars.com/lancerevolution/index.html
EVOLUTION RS LANCER
EVOLUTION VIII LANCER
EVOLUTION MR
Engine Type: Inline-4 Inline-4 Inline-4
Engine Block: Cast Iron Cast Iron Cast Iron
Cylinder Head: Aluminum Aluminum Aluminum
Displacement (cc): 1997 1997 1997
Horsepower @ rpm (SAE net): 276@6500 276@6500 276@6500
Torque (lb-ft @ rpm): 286@3500 286@3500 286@3500
Redline (rpm): 7000 7000 7000
Bore and Stroke (mm): 85.0 x 88.0 85.0 x 88.0 85.0 x 88.0
Compression Ratio: 8.8:1 8.8:1 8.8:1
Valvetrain: DOHC 16-Valve DOHC 16-Valve DOHC 16-Valve
Full-time AWD with Active Center Differential, front helical torque-sensing limited slip differential and rear 1.5 limited-slip differential:
Valve Cover: Magnesium Magnesium Magnesium
Ventilated BREMBO® Disc Brakes with Aluminium Caliper Housings, front: 320 mm dia. rotor,
4-piston calipers 320 mm dia. rotor,
4-piston calipers
Ventilated BREMBO® Disc Brakes with Aluminium Caliper Housings, rear: 300 mm dia. rotor,
2-piston calipers 300 mm dia. rotor,
2-piston calipers
Fuel Delivery: ECI-MULTI Electronic
Fuel Injection ECI-MULTI Electronic
Engine Oil Type: 100% Synthetic 100% Synthetic 100% Synthetic
Turbocharger Type: TD05HR-16G6-10.5T
(Twin Scroll Turbine) TD05HR-16G6-10.5T
EVOLUTION RS LANCER
EVOLUTION MR
Drive Train: Full-Time All-Wheel Drive with Active Center Differential, Front Helical Torque-Sensing Limited Slip Differential and a Rear Mechanical 1.5 Limited-Slip Differential.
Transmission Type: 5-Speed Manual 5-Speed Manual 6-Speed Manual
EVOLUTION RS LANCER
EVOLUTION MR
Front Suspension: MacPherson Strut with Inverted Shock Absorber, Forged Aluminum Lower Control Arms, Stabilizer Bar and Front Strut Tower Brace.
MacPherson Strut with Inverted Bilstein® Shock Absorber, Forged Aluminum Lower Control Arms, Stabilizer Bar and Front Strut Tower Brace.
Front Stabilizer Bar Diameter (mm): 24 24 24
Rear Suspension: Multi-Link Wishbone Configuration using Forged Aluminum Trailing and Lateral Links, Cast Aluminum Crossmember, Stabilizer Bar.
Rear Stabilizer Bar Diameter (mm, diameter): 22 22 22
Wheels: 17" x 8" Enkei® Alloy Wheels
17" x 8" BBS® One-piece Forged Aluminum Wheels
Tires: 235/45 R17 93W Yokohama ADVAN® high-grip tires
Rear End Cross Bar:
EVOLUTION RS LANCER
EVOLUTION MR
City/Highway (mpg/mpg): 19/26 19/26 19/26
Recommended Fuel: Premium Premium Premium
Fuel Tank Capacity (gal): 14 14 14
Old Jan 26, 2005 | 02:51 PM
BUFF BOY's Avatar
whats the MR diferent from the evo 8 ?
GTKage's Avatar
welcome to the forum
Well I think the specs of the evo in australia might be a lil different from the evo here in the US.
05 EVO 8 has a claimed 276hp and 286 ft-lbs of torque ( but everyone knows those numbers are underrated), ACD ( active center differential) , in australia you might get the active yaw control as well ( AYC). Performance wise the evo and STI are very close, it all depends on the driver. I love my 05 evo, very easy to drive fast, and very easy to live with everyday.
Old Jan 26, 2005 | 02:52 PM
GTKage's Avatar
MR get 6 speed gear box, upgraded shocks, and vortex generator on the roof, but same hp than the others
Old Jan 26, 2005 | 02:53 PM
F&I-EVO's Avatar
test drive them both and pick one!
mrbkkt1's Avatar
if i lived in oz, no matter how much i love my evo, i probably would get an r-34, or an s-15. i saw @ borders a magazine called fast fours from australia.- they have lots of info about aussie cars and specs.
Old Jan 26, 2005 | 02:55 PM
oguratevo's Avatar
The MR has aluminum roof, 6-speed tranny, bilstein shocks, BBS forged wheels.
Old Jan 26, 2005 | 02:56 PM
oguratevo's Avatar
Get the MR!
Old Jan 26, 2005 | 03:00 PM
gtr's Avatar
gtr
Get the MR. It rides better than the STi and does not understeer as much.
Old Jan 26, 2005 | 03:04 PM
Steiner's Avatar
hi
cheers
How much do each of these cars cost in Australia?
Old Jan 26, 2005 | 03:08 PM
evo81's Avatar
evo
Old Jan 26, 2005 | 03:12 PM
BUFF BOY's Avatar
both around about $60.000
but recent price drop for the 05STi only $56-57.000
Old Jan 26, 2005 | 03:26 PM
Mr.MR's Avatar
I was thinking about the 05 STi before I got my MR. I could of had one for $29,000. I ended getting the MR for a few reasons.
1. I like the styling better, meaner looking exterior.
2. The MR handles a little better, sharper steering and quicker reflexes.
3. I loved the graphite gray with matching BBS rims.
I did like the interior of the STi a little more due to the 6-disc changer/better system and nicer hvac controls. I liked the seats in the EVO though, a little more comfortable to me. Hope that helps ya somewhat.
Old Jan 26, 2005 | 03:29 PM
moab3man's Avatar
this is an evo forum so pretty much everyone is going to say evo unless some of the subaru troll's come out
