Hallman pro rx heavy spring
Old Jan 26, 2005 | 08:14 PM
tequila083's Avatar
I am going to install the hallman pro rx MBC do i have to use the heavy spring with the ceramic ball or i should use the light spring. I would like to boost 19.5 to redline.
With the mbc full close i read in some post that i should boost about 11 pounds. aprox., how many full turns do i have to move the knob to reach 19.5?
Old Jan 26, 2005 | 08:15 PM
plokivos's Avatar
heavy spring.
2 1/2 then go from there.
Old Jan 26, 2005 | 08:48 PM
Jakeg97's Avatar
yes you need the heavy spring, not sure on how many turns. do you have a boost gauge?
Old Jan 26, 2005 | 08:58 PM
HxllxMan's Avatar
I have the small spring and turn + to max. I'm stuck at 19 PSI.
So will need to install the Heavy spring
Old Jan 27, 2005 | 06:39 PM
tequila083's Avatar
I have a boost gauge i boost 19 without mbc but over 5500 rmp the boost drop to 17, for now i'm not planning boost over 19 can i use this with the light spring.
When you order the hallman rx pro it came with the heavy spring installed or with the light.
Old Jan 27, 2005 | 11:06 PM
Jakeg97's Avatar
if you order it from www.boostcontroller.com it comes with the light spring installed, but also has the heavy spring for an easy replacement / switchout
Old Jan 28, 2005 | 05:33 AM
EvoSlr's Avatar
ehheeh
Old Jan 28, 2005 | 05:35 AM
negativeB's Avatar
you don't need to use the heavy spring. i boost 20.5 with the lighter spring.
Old Jan 28, 2005 | 05:50 AM
broeli's Avatar
It will come with light spring installed. It only takes a minute to put in the supplied heavy spring though. I couldn't even get to 19lbs with the light spring. You'll definitely want to install the heavy spring..
Old Jan 28, 2005 | 05:57 AM
negativeB's Avatar
wow, am i the only person who is able to hold over 19psi with the lighter spring?
Old Jan 28, 2005 | 06:14 AM
NOVA EVO's Avatar
I guess you're just too farking legit, dude...
Old Jan 28, 2005 | 07:58 AM
Jakeg97's Avatar
i guess so
Old Jan 28, 2005 | 09:36 AM
GottaGoFaster's Avatar
Nope...I boost to 21psi and hold with the light spring
Old Jan 28, 2005 | 03:44 PM
plokivos's Avatar
what boost gauge you guys using? Are you sure you're not just spiking to 21psi with light springs then tapering?
Old Jan 28, 2005 | 03:51 PM
HxllxMan's Avatar
I'm using the Defi-D gauge.
I try today again to boost over 19 PSI with light spring, and I'm still stuck at 19.5 now. I check everything, no leak or whatever. Boost keep to 19.5 PSI all the way.
So I guess no leak problem.
