Compressor surge @ low boost
Old Feb 18, 2005 | 09:03 PM
Wicked's Avatar
I just installe a hallman mbc last week and it was running fine until 2 days ago. Now whenever i let off the throttle at a low boost level instead of "blowing off" it makes a fluttering sound... I heard compressor surge can whipe out a turbo after time. I checked all vaccume lines to make sure none popped off and everything looks good. Any thoughts as to what it can be?
Old Feb 18, 2005 | 09:05 PM
Fourdoor's Avatar
The vacuum line is still connected to your BOV correctly? Make sure that section of the line isn't split open, or disconnected.
Keith
Old Feb 18, 2005 | 09:15 PM
Wicked's Avatar
This was my first thought, I checked my routing of all the lines and checked the lines to make sure they didn't melt because they are so close to the manifold, all looks to be hooked up right. Maybe the BOV croked? I've never heard of this but I have no idea... Thanks for the suggestion.
Keith
Old Feb 18, 2005 | 09:16 PM
Wicked's Avatar
Also, it still opens @ high boost, maybe about 10psi or <
Old Feb 19, 2005 | 12:53 AM
plokivos's Avatar
maybe it's not giving you enough pressure to open the valve completely, causing fluttering.
It seems normal at low boost on evos, especially with HKS SSQ Bov.
Try adjusting the bolt on top, maybe that could help.
Old Feb 19, 2005 | 01:59 AM
Wicked's Avatar
scary thing is i'm running the MR BPV....
think maybe more boost is crapping it out? anyone running 22psi with a mr bpv?
CharliEvo8
Jan 5, 2025 10:14 AM
PatricksEvilEvo
16
Feb 3, 2013 05:45 PM
BoosTyEVO
Sep 2, 2011 09:33 PM
ItalianEvo
Dec 20, 2007 12:53 AM
twinturbozs
Jan 18, 2006 11:22 AM
