How to make keyless entry *not* honk?
Old Feb 21, 2005 | 04:07 PM
dizzigital's Avatar
Originally Posted by newmr
Just went to the car and did it the way I described. Worked the first time.
*books it downstairs
ct9a gsr's Avatar
Have my manual here:
"Horn deactivation/reactivation"
1. Press the LOCK button for 4 to 10 seconds and press the UNLOCK button during this time.
2. Press the LOCK and UNLOCK buttons with on 10 seonds of pressing the UNLOCK button in step 1.
hmm... i might sound like an idiot here... but the steps are a little vague...
Do I hold the LOCK for 4-10, then press UNLOCK while STILL holding down LOCK? or do I let go of LOCK and press UNLOCK?
In step 2, do I press LOCK and UNLOCK at the same time? or do I press either? Do I still hold LOCK from step 1?
I'll find out for myself soon, I've tried many combo's so far... but my neighbors keep wondering wtf that honking and blinking is... har har
Old Feb 21, 2005 | 04:08 PM
newmr's Avatar
If you have you manual it is on page 3-7. You can also turn off the turn signals when you lock/unlock if you want so they don't blink.
Old Feb 21, 2005 | 04:09 PM
dizzigital's Avatar
OMG it worked! Didn't even have to run downstairs!
newmr's Avatar
1. Hold down lock for at least 4 seconds.
2. Press unlock once while still holding down lock.
3. Release lock.
4. Immediately after, press lock once and then unlock once.
5. No beep
Old Feb 21, 2005 | 04:10 PM
neilschelly's Avatar
Tried holding both for 4-10, then releasing both at the same time... tried holding LOCK for 4-10, then holding UNLOCK for 1-3, then releasing both... neither worked... still honks and my neighbors are getting irritated now. =]
As I recall, it took a little work to get the hang of it when I did it to mine. Also, be aware there are three modes this will cycle between.
Mode 1: Beep whenever you lock it.
Mode 2: Only blink first time you lock it. Beep/Blink on all subsequent hits.
Mode 3: Only blink ever.
Anyway, maybe you'd be better off waiting for daytime so as not to annoy anyone.
-N
dizzigital's Avatar
3. Release lock.
5. No beep
Yay-yuh!!!
Old Feb 21, 2005 | 04:11 PM
dizzigital's Avatar
Good, I was hating how it was WEAK sometimes and CRISP others.
GREAT CALL.
MYEVOVIII's Avatar
I'm standing on my balcony, hoping all this hail isn't leaving any marks on my Evo... (I'm dead-center in the current tornado(s) in the Atlanta area right now)...
Man sorry to here you Evo outside luckily mine is tucked away in the Garage but the hail is pretty big I went to shut mu Garage door and it was all over the floor pretty big hail storm for GA.
Old Feb 21, 2005 | 04:12 PM
ct9a gsr's Avatar
3. Release lock.
5. No beep
YAY, thanks!!!
Old Feb 21, 2005 | 04:13 PM
MYEVOVIII's Avatar
Originally Posted by rburris28
WRONG! There is a way that is listed in the manual, but I can't go outside right now to check; I'm doing my taxes and typing in between TurboTax updates!
My bad I was not actually recommending that he do that. Sorry
newmr's Avatar
YAY, thanks!!!
No problem. Directions in manual pretty short.
Old Feb 21, 2005 | 04:16 PM
tokeone's Avatar
woo hoo. its about time i dont have the damn honk!
Old Feb 21, 2005 | 05:15 PM
modvp's Avatar
Originally Posted by imapunkclaimer
It says
"Press the LOCK switch for 4 to 10 seconds and press the unlock switch during this time. Then Release the LOCK and UNLOCK at the same time."
Thanks! I tried it and it worked.
Old Feb 21, 2005 | 06:42 PM
ebbeast2005's Avatar
when installing a turbo timer if you havent yet there is a white piece of plastice by the ignition then slam the cover really hard and the clip will break off the white plug then it will not beep.....or lock..... I did that and it sucked.
