All Part Number Request Go Here
Old Feb 17, 2011 | 06:26 AM
  #3481
flmr06's Avatar
Is the part number for the front wheel hub assembly the same for the passenger and driver sides? MB914617 is the part number, but it doesnt specify on mitsu parts if its passenger or driver side. Thanks guys
Kyle
Old Feb 17, 2011 | 06:53 AM
  #3482
Philisdiller's Avatar
Kyle
Both are the same
Old Feb 17, 2011 | 08:05 AM
  #3483
flmr06's Avatar
Originally Posted by Philisdiller
Both are the same
Awesome, thanks man
Old Feb 18, 2011 | 06:43 PM
  #3484
milruner's Avatar
I need a part number for the piece that that goes inside the fuel door cover, its like a half metal/ half plastic piece. I springs the fuel door open when you pull the fuel lever inside the car. 2005 EVO 8 MR.
MIKE
  #3485
milruner's Avatar
double post. sorry.
MIKE
Old Feb 18, 2011 | 08:10 PM
  #3486
HxllxMan's Avatar
Are the cam position sensor the same for the exhaust and intake side?
Old Feb 18, 2011 | 10:21 PM
  #3487
MarksIX's Avatar
Need part # for the Red O ring gasket/seal that goes on IX turbo CHRA on the compressor side. PM if possible Thanks.
Old Feb 19, 2011 | 12:20 AM
  #3488
jaredh's Avatar
MIKE
i need that too! let me know if u find the part number!
Old Feb 19, 2011 | 05:35 AM
  #3489
rtsr's Avatar
I need the isc o-ring part number and the o-ring that is inside the throttle body on the side.
Thanks
Old Feb 19, 2011 | 09:52 AM
  #3490
milruner's Avatar
ok will do.
MIKE
Old Feb 20, 2011 | 10:30 AM
  #3491
kimbo305's Avatar
I'm looking for the trunk light assembly for a 2003 Evo 8. What I have is the plug that should terminate into the plastic holder for the trunk light. If the bulb and assembly are two different parts, I guess I need both?
I also need the plastic screw cover that fits into the driver's side front door release (the one inside the car).
I'm new to Evos; is there an online Mitsubishi parts store where I can take parts numbers and plug them into an online inventory, like this?:
http://www.hondaautomotiveparts.com/...atcgry5=SWITCH
Old Feb 20, 2011 | 06:57 PM
  #3492
JDMCT9MR's Avatar
I need the part number for my EVO X GSR for the bracket that connects the drivers side rear bumper to the car. Here is a pic. The bracket sits right behind the rear bumper starting from the fender well to the base of the taillight.
It is almost a L-shaped bracket that is connected to the body of the car by 4-5 bolts. Mine was broken by the previous owner. Thanks in advance!
Old Feb 21, 2011 | 11:01 PM
  #3493
Rob#2's Avatar
I need the part # for the clear film that is on the front of the rear wheel well next to the door.
No it is not, although they look identical they are different part #'s
Old Feb 21, 2011 | 11:54 PM
  #3494
HxllxMan's Avatar
I found that one, but can't get hand on the other one :/
MD327107 cam position sensor (exhaust)
Old Feb 22, 2011 | 07:56 PM
  #3495
Rob#2's Avatar
MR507814 is the intake cam position sensor on a IX
