All Part Number Request Go Here
Old Jun 29, 2020 | 02:23 PM
  #4651
osetsky's Avatar
Anyone ever find a part number for the ACD pump solenoid?
This sucker here, anyone got a part#? It's busted in half...
Old Dec 28, 2020 | 05:13 AM
  #4652
thepoint4life23's Avatar
anyone know the part number for the screws into this
Old Dec 28, 2020 | 06:01 AM
  #4653
@thepoint4life23
From what i can see its item no. 73935 which are part no.s MF453093 or MF453273
You can double check all this on:https://partsouq.com/
Old Jan 4, 2021 | 02:04 PM
  #4654
EvoooB's Avatar
Hello, I'm looking for the firewall insulator for a USDM Evo 9, P/N MR974599/ MR479855 in the picture below. Do you happen to have any connections on where I could find this, or if possibly the same piece is used on the base Lancers/ other models? I'm desperate..... thank you in advance.
Old Jan 4, 2021 | 03:31 PM
  #4655
Mitsu has discontinued their support of many EvO parts. My guess is a salvage yard would be best to source?
Old Feb 7, 2021 | 03:12 PM
  #4656
car2021's Avatar
Need help identifying car part
hi everyone, I am looking for help identifying this car part. I think it might be an evo (because of the FQ) but i'm not sure. is this a custom side mirror mod or does anyone know what evo car year or make it could be from?
thanks
Old Feb 8, 2021 | 08:54 AM
  #4657
thanks
Hello / Welcome @car2021
Pretty sure that is not an EvO 8 or 9 mirror & that FQ symbol has nothing to do w/the British EvO FQ model. Is there a Mitsubishi logo on the mirror?
Old Apr 22, 2021 | 10:17 AM
  #4658
kpt6's Avatar
Can someone please help with a part number for passenger rear window regulator?
Old Apr 22, 2021 | 02:12 PM
  #4659
GaBe511's Avatar
This should be passenger (RH) regulator MN126738
Old May 2, 2021 | 12:27 PM
  #4660
kpt6's Avatar
Incorrect. That was for front passenger.
Also I bought MR991330 and that was incorrect also. That was for a Lancer rear passenger window regulator.
Anyone have any ideas? @MinusPrevious ?
Old May 2, 2021 | 02:49 PM
  #4661
This is what i come up with:
  • MN126737 & MN126738
Old May 3, 2021 | 12:28 AM
  #4662
kpt6's Avatar
Thank you. Unfortunately pulling up the same Lancer rear one I already bought. Motor different and can't swap in my old one, and harness different as well. The motor is fine on my old one but the cable was destroyed.
Old May 5, 2021 | 03:24 PM
  #4663
JB2003OZ's Avatar
I have a 2003 Mitsubishi Lancer OZ Rally with Automatic Transmission. I believe it is the F4a42 Automatic Transmission. Getting ready to replace both driver and passenger side CV axles. Can anyone help with the part number for the CV axle seals? (The seals in the transmission that go around the axle shaft when you push it into the transmission.)
Nothing leaking now and I plan on being careful and damaging the seals when removing and installing the seals. However I'd like to have replacements on hand in case I mess them up or they look worse than I thought. All the online parts catalogs aren't that clear and I want to make sure I order the right part. I think they may be MD755526 but other catalogs indicate there's a difference between right and left etc or indicate MN120496 MN130498. The more I search the more confused I get lol.
Old Jun 18, 2021 | 08:35 PM
  #4664
osetsky's Avatar
Rear hubs...are they the same as 3000GT's like the fronts apparently are? I'm trying to find a compatible non OEM and rag on me all you want but OEM is 700$ish dollars and that is just bat**** crazy! So yeah, looking for a sensible option.
Old Jun 19, 2021 | 07:04 AM
  #4665
@osetsky
MR403968 or can substitute with MB892400 (per https://partsouq.com/)
