how much power can i expect with these mods?
Old Mar 3, 2005 | 03:11 PM
crazynyevo's Avatar
Question how much power can i expect with these mods?
I have 2004 evo 8 and i was considering doing asome mods to my car. What horsepower increase should I see if I install these mods listed below:
1) helix 3" downpipe
2) Helix high flow cat
3) helix 3" catback exhaust or greddy titanium catback
4) buschur mini filter (just filter not hardpipe)
5) run boost at 19 psi
6) walboro fuel pump
7) some type of ecu relash (either dynoflash or maybe vishnu tune)
I was looking to make 340 crank hp safely without using cams. I don't go to the racetrack but I have a heavy foot I want a car with some *****. I have 5000 miles on the car and It hasn't been launched once! Im not a fan of cams because I live in NYC and they are strict with the emmission stuff plus they seem to cause oil consumption on some cars. If anybody has a good estimate with a breakdown of each item I would greatly appreciate it. The reason im shooting for 340 bhp because the clutch is 2200 lb unit (best info I could find) it should be able to handle 340 safely and about 380 maximum. I used to have a DSM so that was the normal limits of safety on like ACT 2100 clutch.
Old Mar 3, 2005 | 03:37 PM
oguratevo's Avatar
Take it to a dyno run to get some numbers. Goodluck!
Old Mar 3, 2005 | 03:48 PM
GTKage's Avatar
with all those mods, u ll be able to reach your goal of 340 crank hp quiet easly. but one day or another u ll need a new clutch, for your setup a act street disc will be plenty enuff.
Old Mar 3, 2005 | 03:58 PM
Boosted1's Avatar
Well I have Aps intake, Perrin TBE, Boost controller, Utec, and fuel pump and I put down 314hp, and 340 lbft, to the ground. So yeah Its possible.
Old Mar 3, 2005 | 04:01 PM
Kuba23's Avatar
290 WHP at 19 psi and 305 with 21 psi WHP that is
Old Mar 3, 2005 | 04:08 PM
thatsMR2u's Avatar
everycar on this forum reacts to mods with different hp numbers, but id suggest since u have a 2004, a 20g turbo upgrade (from buscher). a ecutek flash to go with it (no need for a mbc), and a catback exhaust and have all that horsepower that you want and still have warranty on your car,,, but i will stil answer your question and with those mods you should get about 320whp (with a conservative flash and 91 octaine)
Old Mar 3, 2005 | 04:16 PM
jeffm1999's Avatar
1.Turboback exhaust w/ cat = about 15 HP plus quicker turbo spool
2. Air filter= a loss in HP/TQ until reflash, then maybe 4-6 peak HP
3.Reflash= Best mod on your list... about 25-30 peak HP and boost will not taper to 15 after 3 seconds of WOT, holds about 19 to redline. (Dynoflash worked for me.. I highly recommend going with them)
4.Fuel pump= safety mod, wont gain you any HP but you wont run lean under high boost or hit fuel cut.
5. as for running boost at 19 psi, you should already be running that, if not you have a leak somewhere.
6. may I also recommend getting a Hallman or other manual boost controller as a Turboback exhaust will cause boost to momentarily spike at about 21-22 psi
Old Mar 3, 2005 | 04:19 PM
tke_413's Avatar
What dyno are you talking about. On a Mustang dyno those mods will put you right about to my numbers.
Old Mar 3, 2005 | 05:42 PM
onesicklambo's Avatar
i have
cat delete
cat back
drop in filter
works p2 flash
i dynoed in at 265 @19psi.
this was a DYNAPACK dyno
Old Mar 3, 2005 | 05:44 PM
MYEVOVIII's Avatar
I think about the same as Kuba23
Old Mar 3, 2005 | 05:46 PM
Kuba23's Avatar
Why not raise the boost ??? why keep it at 19 ?
