shifting my MR from 5th to 6th
Old Mar 10, 2005 | 06:19 AM
GR8SHAG's Avatar
Thanks for all the responses to my first post on buying my MR. I have a question for MR owners. I notice, especially when its cold that my car is quite difficult to shift from 5th to 6th gear. If I dont push fairly hard to the right while shifting I end up back in 4th gear. It isnt a problem now during break in as my revs arent up but I worry about it in the future. Do you think this is something associated with the cold or newness of the vehicle?? I have had two bmw cooper s models with six speeds and dont remember having this happen with them. Thanks....Phil
Old Mar 10, 2005 | 06:24 AM
Kronik's Avatar
I think it has to do with the cold -- after you run your car for awhile does it still do this?
Old Mar 10, 2005 | 06:28 AM
GR8SHAG's Avatar
Kronik,
I am not sure if it changes after warming up. I only get on the freeway for two miles on the way to work so it is basically one shift into 6th gear. I will do some driving today and see if it inproves as the car warms up. Thanks...Phil
Old Mar 10, 2005 | 07:14 AM
k.lowe's Avatar
try letting the car warm up before you drive
Old Mar 10, 2005 | 07:19 AM
bigjhoney's Avatar
I dont got the six speed, but when the cars cold, especially in this weather, makes the shifting very hard/notchy until it warms up. I would take it for a decent ride and , and then try shifting into 6th, im sure it will be fine then.
Greg K's Avatar
not really a function of temperature, it's not difficulty engaging; more missing the gate due to the spring tension. mine was like that for a while during breakin. don't even notice it now. It's not like a 3-4 upshift where it falls into the gate. It will always require some side pressure due to the centering spring in the shifter base. After a thousand miles or so it softens up a bit, and you adapt and won't even notice it. I'm at 8500 now and it's like second nature.
Greg
Old Mar 10, 2005 | 08:50 AM
hutch959's Avatar
Greg
what he said
Old Mar 10, 2005 | 09:33 AM
GR8SHAG's Avatar
Greg K
Thanks everyone for the info. Greg my dad drove a sierra while working in england, it was i think a glsi. What type of rally car do you have? I sold a 66 lotus cortina in the fall and miss it very much.
Old Mar 10, 2005 | 12:45 PM
Greg K's Avatar
mine is the 1990 sapphire cosworth. 4door, motorsport shell, with a 2liter YBG cosworth engine, 200 cooper ringed block, 4x4 head, burton cams, T34 escort cosworth "homologation" turbo, 5.5" Grp A downpipe to 3" exhaust, no muffler, hf cat at the very back. running an ahmed bayjoo chip good for about 300hp in current tune. Will be about 350+ next year once I install autronic and get more comfortable with the car. Converted to rwd to run the USA gravel rally series in 2wd open class.
Old Mar 10, 2005 | 08:56 PM
Jakeg97's Avatar
thats always a good idea. make sure its warmed up before pushing the car hard
Old Mar 11, 2005 | 04:16 AM
WarmPepsi's Avatar
yeah, same as the 6 speed in my rsx, the mr tranny has a slight clunk for the first few shifts when first starting up and leavin, but never any problems with 6th.
