wiper fluid all over hood...
Old Mar 13, 2005 | 06:42 PM
Steiner's Avatar
I washed my car on Thursday for the first time since I bought it. It's been raining her in NorCal for the last 2 weeks almost non-stop. I didn't notice any chips or unusual engine fluids on the car when I was cleaning it. But later that night when I pulled into the garage I noticed that there was blue windshield wiper fluid/concentrate all over the hood. It was all around the edges of the scoop, down the side of the car and all over the driver side of the hood. It looked like it had been leaking out of the driver side nozzle. I got a warm wet cloth and cleaned it off. Next morning I come out and it looks like it has been slowly dripping out of the nozzle and onto the hood all night. I cleaned it up all the blue fluid but noticed there are 2 faint yellow stains now on the paint where the fluid had been dripping down. So I got two questions...
1.) What can I use to safely take of those little yellow stains?
2.) Has anybody ever had this problem with wiper fluid leaking out of one of the jet nozzles? If so, how did you fix it?
Old Mar 13, 2005 | 07:23 PM
EVIL_EVO_VIII's Avatar
I had the same problem but mine wasnt leaking and it left a damn stain on my hood. I tried to buff it and wax it but it wont come off it looks like it got under the clearcoat
Old Mar 13, 2005 | 07:26 PM
evo_il8's Avatar
sry to hear
Old Mar 13, 2005 | 07:33 PM
afropopo's Avatar
try using some paint clay, and polish. Several coats of a good polish may do it, but it is hard to tell b/c i don't know what it looks like on your hood. check out www.griotsgarage.com for their paint clay and polish. i use their stuff, and it is a lot better than mcguires and all of that other cheap stuff. it's worth a try, but even if it doesn't work, you still have some kick *** cleaning supplies to use.
Old Mar 13, 2005 | 07:42 PM
Steiner's Avatar
Thanks for the info guys. Any idea what's causing the wiper fluid to overflow? I looked under the hood with a flashlight to see if it was a leak where the line meets the bottom of the nozzle but everything looks clean. Nothing spilled on the engine as fas as I could tell. Could it be air in the line or something like that? Seems like such a small thing to take it to a dealer for so I'd just assume fix it on my own and be done with it.
Old Jul 21, 2005 | 05:23 PM
Fourgig's Avatar
Anyone else having this problem? My nozzles pees wiper fluid all over my hood almost every morning on the way to work. Doesn't seem to do it at any other time.
Old Jul 21, 2005 | 05:47 PM
evohead1's Avatar
a 3 weeks ago i put washer fluid in, it was empty, i saw fluid over my hood, mostly spilled out when i braked.It went away and I have not seen it back in over a 2 weeks.
Old Jul 21, 2005 | 06:24 PM
PeteyTurbo's Avatar
There should be a little hole on the resivior cap or somewhere on the top of the resivoir to let air breathe, it is most likely clogged which is why your nozzles seep fluid onto your hood..
