Getting Shocked with Cyber Speed
Old Mar 15, 2005 | 11:29 PM
mikiblueeyes's Avatar
Just installed Sun Automotives, Hyper Voltage System and now everytime i get out of the car I get shoked with static. All the install was according their manual.
Does anyone had similar experience or knows how to fix that??
Thanks.
Old Mar 15, 2005 | 11:31 PM
RaceBiscuit's Avatar
pardon my ignorance, but what exactly does the Hyper Voltage System do?
Old Mar 15, 2005 | 11:43 PM
Its a grounding system that suppose to add about 10HP
Old Mar 15, 2005 | 11:47 PM
ahhh... sorry I can't help you fix it. I've heard of quite a few STOCK Evo owners getting shocked by their cars, though...
Old Mar 16, 2005 | 12:07 AM
binsquared's Avatar
yea i get hella shocked when i try to close my door...
does this have anything to do with bad grounding?
Old Mar 16, 2005 | 12:58 AM
the only factor that seems to be constant in the "shockings" is colder weather. hahaha LOL sounds like some horrible B horror movie, eh?
Old Mar 16, 2005 | 01:10 AM
Tureno-AE86's Avatar
are you guys that desprate for 10 hp?
10 hp dont make much difference on a track if you have the skill
i would just remove the device see if you still get shock
thats prolly the best way to figure it out
Old Mar 16, 2005 | 03:31 AM
Drill_Sergeant's Avatar
Veteran: Army
mine was shocking me and other people for the first month too.
Old Mar 16, 2005 | 05:51 AM
kdogg's Avatar
Hyperground kits offer a better ground for the car's entire electrical current. It isn't intended to stop the static built up when you're driving. That static is good 'ol friction with help from dryer air. Just touch metal (like door frame or a pillar) before you put your foot on the ground when you get out.
P.S. Either your pic's resolution is really crappy or your engine bay is a little roughed up.
Old Mar 16, 2005 | 09:39 AM
Thats the thing I wasnt geting shocked before I installed the system, and after the install just siting in the car for 20 seconds gives fairly strong discharge once i get out.
Anyone installed the same system? Did I do something wrong?
Old Mar 16, 2005 | 09:44 AM
EVOTEXAS's Avatar
this is not the cause.
Old Mar 16, 2005 | 09:46 AM
chinto's Avatar
shock most likely nothing to do with grounding.. try driveing with the heat off.. or when u get outa the car hold onto the door whyll steping down you will be ok.
Old Mar 16, 2005 | 09:53 AM
well before I installed the system I har just regular 4 Guage grounding wires and had no static, now after adding active sytem (look at the pic, blue little box by the swithcbox) without even driving the car, it collects static
Old Mar 16, 2005 | 09:56 AM
EVOTEXAS's Avatar
No it doesn't. Your body collects static from the carpet and seats. Look at other changes. Weather, shoes, clothes, etc. You get all staticed up and get out and ground yourself to the car. Touch the car first and let it absorb your charge then let your foot touch the ground. No shock. It's you who is collecting the static.
Old Mar 16, 2005 | 09:58 AM
justchil's Avatar
grab the door before your feet hit the ground and you shouldn't have any problem
