service engine light
Old Mar 29, 2005 | 12:57 PM
4TUN8's Avatar
Don't think an exhaust leak will effect your boost.....unless the leak was between the turbo and the manifold.....
Old Mar 29, 2005 | 01:02 PM
bigcountry's Avatar
put a spacer between the 02 sensor and the exhaust pretty sure the anti foul spark plug spacer fits in there ive got a 90 like the other guy said but if you cant weld this whould be cheaper/easy
Old Mar 29, 2005 | 01:23 PM
GTKage's Avatar
Originally Posted by d3wu
i haven't had time to read the code yet, but I have my service light on and have a high flow cat..
if i have an exhaust leak, i should notice a change in boost right?
because my boost seems to be spooling and holding fine in each gear..my guess is the service light is on because of the p0300 code
no my exhaust was leaking and i didnt have any drop in boost, most people in here with a HF cat that get a P0420 code should first check for leaks, your cat might be working properly, it just that the flanges where the cat and cat-back meet might not be totally compatible and need to be double gasketed or try to find a way to bend the flanges so they meet perfectly.
Old Mar 29, 2005 | 01:27 PM
justchil's Avatar
Still have had a chance to check for leaks.. P0420 again today I really hope my dp isn't leaking because I had it welded to the cat.. I'll have to damn near drop the entire exhaust to take it off
Old Mar 29, 2005 | 01:38 PM
GTKage's Avatar
it s mostlikly leaking where the cat and cat-back meet. check there
Old Mar 29, 2005 | 02:17 PM
justchil's Avatar
Looks like where the dp meets the cat.. the ONLY place I had it welded because i screwed up my clamp and it was leaking worse.. I'll take pics of the weld.. after looking at it i'm not happy at all. I really thing I could do a better job but I don't have a welder powerful enough for exhaust work.
I'm taking pics now
Old Mar 29, 2005 | 02:38 PM
justchil's Avatar
Ok here are the pics.. It's hard to take decent pictures under the car but I did the best I could.. The weld looks like it has 2 holes 1 of which had some nice black crud almost dripping out
These pics were taking after I cleaned it up.. The weld doesnt look half bad for the top portion but the rest looks like a 5th grader did it.. Needless to say I'm going to take this back to get fixed asap.
and just for kicks a 100% non leaky BR bandclamp (where cat meets catback)
Old Mar 29, 2005 | 03:19 PM
GTKage's Avatar
i c
well the only way to see if it leaking it to let the engine run and pass your hand where u think it s leaking, u will feel it with your hand, be carefull dont burn yourself
Old Mar 29, 2005 | 03:48 PM
justchil's Avatar
Yeah that's next
There is great evidence of 1 possibly 2 leaks in the welds
Old Mar 29, 2005 | 04:56 PM
justchil's Avatar
Yup mines leaking.. both holes.. I've only got a little cheap mig so I guess Ill have to take it somewhere to get fixed.. this is why I have no trust in local shops
