which boost gauge??
Old Mar 29, 2005 | 11:22 AM
bonestockevo8's Avatar
Originally Posted by Dr. SS
whats the mm HG measurements below the PSI readings? does it sit at 0 or below to indicate some sort of vacuum? thanks in advance for the info.
not at 0, somewhere around 20 if I remember correctly
Old Mar 29, 2005 | 02:10 PM
krafty's Avatar
You are correct....
Old Mar 29, 2005 | 04:12 PM
Dr. SS's Avatar
so wait, when i install this thing its not goint to sit at 0, its going to sit at 20 mm Hg and then swing up past 0 into PSI territory to give me boost levels?
oh and, where did y'all order your defi-d? basically any vendor that carries them?
Old Mar 29, 2005 | 09:54 PM
krafty's Avatar
Found a pic of the defi in a BR pod mounted on the right http://gallery.evolutionm.net/showphoto.php?photo=1827
As for the reading. it should sit at 0 when the car is off, and around 20 mmHG when the car is idling, because it is drawing a vaccumm. It will rise to 0 once the turbo is spooling, and go into the psi under boost.
Old Mar 29, 2005 | 11:41 PM
RaceBiscuit's Avatar
I ordered my D-series from egauges.com
Unless someone knows differently, I believe that's the cheapest place to buy them. Quick shipping, too. If you can afford it, a lot of people like the BF series because they match the stock gauge cluster almost perfectly. My brother has the Greddy Blacklite (or whatever its called) boost gauge and it looks awesome. He's never had any problems with it. As far as Autometer, I too, have heard mixed reviews.
Old Mar 29, 2005 | 11:56 PM
mobounce's Avatar
Just get a Turbosmart E-Boost controller / gauge... for the money.. you get both AND you can mount on the column like me
You'll get a kick *** gauge and a completely tuneable and high quality electronic boost controller all in one All for about 450 bucks. Some places even cheaper...just my suggestion.
http://www.turbosmart.com.au/
Old Mar 30, 2005 | 07:09 AM
Dr. SS's Avatar
another question has arisen as i read more...
what is the difference between the
"electronic" gauges versus the standar ones...? Is their no vacuum hookup to the electric gauges? + is the BF series defi electric or standard like the d series? thanks in advance....
Old Mar 30, 2005 | 07:12 AM
WNLancer's Avatar
the standard one has the vacuum line that connects directly to the gauge, the electronic has a sender unit that can just send wires to the gauge.
Old Mar 30, 2005 | 07:14 AM
kdogg's Avatar
Standard (mechanical) gauges have the vacuum tubing go directly to the back of the gauge. In an electrical gauge, the tubing is connected to an electric sensor box. A simple wire is connected to the gauge from that sensor box. BF series are electrical while D-series are all mechanical.
Old Mar 30, 2005 | 07:42 AM
Dr. SS's Avatar
thanks... is there any accuracy advantage between the two types?
the sensor box... is this small enough to tuck away under the dash someplace? TIA.
Old Mar 30, 2005 | 07:49 AM
Dr. SS's Avatar
I just realized that the Defi BF series are in BAR only... i really prefer PSI.. + the D series are alot cheaper!
i think ive made my choice...
Defi D series... with the buschurracing steering column kit.
black or white face>?
