What to get with new cams?
Old Apr 5, 2005 | 09:14 PM
Kwman's Avatar
^ A fuel pump is (IMHO) necesary seeing as a walbro is only 90 - 100 dollars and cams are 500-560 for HKS's...why the hell not? More air needs more fuel, whether its dangerous or not doesn't matter but i like running 21 PSI with HKS 280 cams.
Old Apr 5, 2005 | 09:16 PM
LEVIII's Avatar
Originally Posted by binsquared
but aren't upgraded fuel pump and injectors only essential only if your gonna be running high boost?
You shouldnt need injectors, and fuel pump unless you get over 400 HP or a bigger turbo
Old Apr 5, 2005 | 09:21 PM
housedj's Avatar
Thumbs up
i would HIGHLY recommend ARP head bolts. the head will stretch the stock bolts if you rev over 7850. for safety reasons AND reliability, i say get the cam gears, lifters, & retainers. a 1.2mm head gasket wouldn't hurt either.
Old Apr 5, 2005 | 09:35 PM
Evo VIII 4o1's Avatar
Originally Posted by 4-BNGR
Fuel Pump
Injectors
FMIC
Tune of Some Kind...
That's 360whp or so... on 93 octane.
No Way.. you are going to need more than that to get 360WHP
Old Apr 5, 2005 | 09:37 PM
binsquared's Avatar
depends on the tune... ive seen lots of people getting a sh*t load of additional power w/ basically stock everything...
Old Apr 6, 2005 | 09:04 AM
Z1 Performance's Avatar
IMHO, the fuel pump is needed (along with a reflash, etc) as soon as you turn the boost up on an Evo...even without cams
injectors become necessary depending on the exact setup of the car, and the cam choice. Most of our customers who do cams and run 21-22 end up with at least a 660 injector
Old Apr 6, 2005 | 11:52 AM
binsquared's Avatar
hmm...i guess i should get new injects and fuel pump just to be on the safe side...
