What to get with new cams?
Old Apr 3, 2005 | 11:31 AM
binsquared's Avatar
Hey All...I was wondering, when getting new cams, usually I'd have to get a new cam gear also. But what other things would I need to get? New retainers? Valve Springs? etc... or are the stock ones good enough?
Old Apr 3, 2005 | 12:22 PM
SilverCOEvo's Avatar
From what I've heard, other things are optional, but good ideas. Some will depend on how aggressive the cams you're getting are. Post that info for a little more feedback as I've heard many people just do swaps, expecially with the 264's, while others do a bit more work. I'm sure people that have done them can chime in a bit more than I can (as I'm basically going to do everything upto cams and see where I end up.)
Old Apr 3, 2005 | 12:41 PM
binsquared's Avatar
I'm thinking of getting 264/264s... I rarely see anyone replacing anything else other than the cam gears...
Old Apr 3, 2005 | 01:49 PM
MANGOOK's Avatar
You dont need cam gears you would want to get head studs but you dont have to. Head studs are just a safety measure. I did hks 272's and just installed the cams nothing else.
Old Apr 3, 2005 | 02:04 PM
koolade9's Avatar
buy new cam seals while you're at it.
Old Apr 3, 2005 | 02:10 PM
sleet's Avatar
When I plan on doing my upgrade, i'm probally just gonna get headstuds and the cams GSC 272s.
Old Apr 3, 2005 | 04:50 PM
qbbraveheart's Avatar
yea when I go 272's Im gonna get headstuds and cams and most likely cam seals
Old Apr 3, 2005 | 04:56 PM
4whlpl's Avatar
I just bought HKS 280's. I am not replacing the cam gears because it is really rare to find any that can compete with the stock ones. But, I am getting new head studs and a new head gasket. I haven't decided whether to replace the head gasket for a stock one or not yet.
Old Apr 3, 2005 | 05:12 PM
lil'evil_evo's Avatar
you only need to replace springs, retainers with jun cams. no need to get gears even. when i had my cams installed i just had head studs installed along with them.
Old Apr 3, 2005 | 05:41 PM
Z1 Performance's Avatar
the only thing you should do at the same time is the head studs if you plan on big boost now or in the future. Everything else is totally extraneous.
Depending on the cam you get, you might need springs and retainers....if you are going HKS, stock stuff is perfectly fine
Old Apr 4, 2005 | 12:14 AM
binsquared's Avatar
awesome...thanks for the input people,..this will surely save me some money
Old Apr 4, 2005 | 09:40 AM
Evoisdream's Avatar
wow im surprised to find out cam gears are not needed really... though they would be?
evoisdream
Old Apr 4, 2005 | 09:42 AM
Kwman's Avatar
I would not do cams without a fuel pump, more air needs more fuel secondly, you're already there so why not do headstuds too?
Old Apr 4, 2005 | 11:20 AM
4-BNGR's Avatar
Fuel Pump
Injectors
FMIC
Tune of Some Kind...
That's 360whp or so... on 93 octane.
Old Apr 5, 2005 | 09:09 PM
binsquared's Avatar
but aren't upgraded fuel pump and injectors only essential only if your gonna be running high boost?
