Found out why new TC is starting to make noises...
Old Apr 7, 2005 | 08:08 AM
RalliArtEvoVIII's Avatar
ok i installed a new TC about 2000mi ago and changed oils TWICE since install on a new TC with royal purple 75w90. Found out why its starting to howl ( i dont launch or do anything of that nature), its leaking right where the TC and tranny connect. SMALL SMAL SMALL droplets of oil are coming out. anyone know what i should use? should i use gasket maker to stop the leak? would that help? i never got a gasket with my new TC so im guessing people usually re-seal em?
Old Apr 7, 2005 | 08:14 AM
mifesto's Avatar
let me ask in details, YOU yourself installed it?
Old Apr 7, 2005 | 08:16 AM
VTECH8TR's Avatar
Get the OEM o rings, that's the best way to seal it.
Old Apr 7, 2005 | 08:18 AM
arent the O rings located on the spline area? if so, i dont think those are missing in anyway. could that be causing the leak?
Old Apr 7, 2005 | 08:50 AM
GTKage's Avatar
get it reinstalled, obviously it s has been installed like crap. and make sure it someone that know what they are doing.
Old Apr 7, 2005 | 08:56 AM
Curt@MrLed's Avatar
Former Vendor
you need a new o-ring in there..thats the only fix..maybe youll get lucky and the seal is cocked of a piece of dirt is on it..but since youll be in there again replace... and how is a leaking gasket causing your t/c to howl...
Old Apr 7, 2005 | 10:29 AM
bigjhoney's Avatar
probably low on fluid and its not lubricating
Old Apr 7, 2005 | 10:39 AM
93civEJ1's Avatar
please dont post retarded stuff.
It happens man...There are 2 o-rings between the tcase and tranny...one small one above the output, you may have pinched the small one. Mine is kinda leaking slowly and will be redoing the small o-ring soon. I have it ready to go, just waiting on a friend to get back from vacation so we can do it.
Old Apr 7, 2005 | 02:16 PM
ahh im sick of this crap, do any of the axles/ driveshaft need to be removed to replace the O ring? Im guessing left side and right side axle so the shaft can be removed to separate the TC and tranny right? damn i might just pay mitsu to do this, how much do u think mitsu will charge for this labor for the O ring replacements? and yea, low on lubrication is why TC is starting to howl, thats pretty obvious.
Old Apr 7, 2005 | 02:31 PM
Compjoc's Avatar
That is the exact same thing that happend to me. My transfer case got low on fluid somehow. I took it into the stealership, and they said it was perfectly fine (obviously they didn't check the fluid). and 7 hours after leaving the service department, my transfer siezed up on the highway (it sucked). Anyway, they ended up replacing under warranty and it has been in for 2 repairs for oil leaking in between the TC and tranny. and its still leakin a little
Old Apr 7, 2005 | 02:37 PM
matt55's Avatar
Same thing happined on my 3RD t-case , one of the seals were leaking . I think the axles come out but the tranny stays in . you might have to get a rebuild if its howling , try teamrip "GEARS" on evom . sorry bro
Old Apr 7, 2005 | 08:48 PM
no, im fine, its starting to make a lil bit of noise but doesnt bug me as much as my first TC, WHOOOAA, i dont think that was a normal howl, when it approcached 40mph, it would overtake any sound on the fwy with a loud metal type rattling noise that was viscious it even scared V8s(ahah), anyways, well seems like this O ring issue isnt a rare thing, so if i take it to Mitsu, how much will i be charged for them to separate, new O ring, and then fill up the TC and tranny.
Old Apr 9, 2005 | 01:06 PM
bump? I tried to get a quote but no luck with it. Im guessin i'll be in it for like 200?
owexonline
Outlander Sport
14
Nov 17, 2021 02:20 PM
My03evo
Apr 20, 2011 10:26 PM
5LEEPERISAH23I
Dec 27, 2010 03:18 PM
Most-Wanted
23
Mar 30, 2006 11:43 PM
RalliArtEvoVIII
Mar 24, 2005 04:36 PM
