Has anyone disabled the 05 rev limiter?
Old Apr 10, 2005 | 08:02 AM
Turbojunkie's Avatar
just checking to see if anyone has disabled the 05 revlimiter? i have a very undiscripive how to on it. I was told to unplug the sensor above the clutch that controlls the two step. there are like 20 plugs under there. any help on this would be kul. thanks guys. billy
Old Apr 10, 2005 | 08:05 AM
nixx's Avatar
Go here:
https://www.evolutionm.net/forums/sh...d.php?t=108697
I did this last night- worked like a charm.
Old Apr 10, 2005 | 10:46 AM
mdosu's Avatar
i don't have an 05 but the limiter is set to 5k? that sucks...is it just for launches on 1st gear or set for any gear at 5k?
Old Apr 10, 2005 | 10:53 AM
mike69's Avatar
You can easily disable the limiter using that guide. Another easy way to raise/remove limiter is to get a flash with "launch control." I think UTEC, Works P2R flash, and XEDE have these, not completely sure, though.
Old Apr 10, 2005 | 11:41 AM
Warrtalon's Avatar
It comes into effect in neutral, which absolutely kills you when launching, as I found out yesterday. The car basically shut down and wouldn't engage until I waited a half second for the rpms to drop again.
Old Apr 10, 2005 | 11:46 AM
Warrtalon's Avatar
Originally Posted by nixx
Go here:
Damn, one day too late. I didn't know how badly this feature affected launches when it kicks in. I do believe the author of this post was right in his assumption that timing is pulled significantly when this happens. My engine didn't shut off, but it was as if I couldn't move. It does NOT let you engage the clutch when this feature clicks on.
Old Apr 10, 2005 | 04:59 PM
thanks for the link guys. I should have done this b4 i went to the track on friday. i did 12.802 @ 108.26. that was with a 1.98 60' I could have easly done a 12.6 with 1.8 60'. thanx agian
Old Apr 10, 2005 | 07:05 PM
Warrtalon's Avatar
Go here:
Btw, I just went out and did this, too. It does work like a charm.
Old Apr 10, 2005 | 07:22 PM
DCSilvrEvo's Avatar
why doesnt anyone like the launch control. Its hard for me 2 launch my evo with ACT clutch. Either i spin or Bog... I must just suck
Old Apr 10, 2005 | 07:46 PM
Warrtalon's Avatar
It's not launch control, it's launch denial. I went and tested it in my driveway and it actually STARTS to pull timing at around 4700rpm, then at 5k it starts bouncing (kinda like idle surge if you've ever heard that) while pulling almost all the timing. You can't even try to launch at that point, so that's why we don't like it.
To get a 12.5@107, you obviously didn't have any trouble launching, because that's an INCREDIBLE time for that mph. Look at all the guys with 12.9 and 13.0 at the same mph. You had to have a 1.65-1.70 60' with that, right? If I had an ACT instead of this crap stock clutch, there's no telling what I could do (including breaking tranny parts).
