Most HP outta of Stock Turbo
Damn, that sounds impossible but I'm not going to doubt it considering it was with the alky set up which apparently should be my next mod. I might meet up with Al if I'm in town the weekend he comes to Dallas. I also saw where he was able to get 423 whp on a basically stock Evo with the T-67 and alky at 19 lbs. That's the kit I'm putting on my car.
Most of these big numbers being produced, you can bank on this statement, are done at boost levels that are in my opinion UNSAFE for a car that is driven daily.
As Al stated on the 494 whp pull he made, it wasn't recommended, BUT it did make that power on pump gas and alky, it was at 32 psi of boost.
David Buschur
www.buschurracing.com
David Buschur
My buddy Was hiting 33 with his 1g on pump gas... He had a P trim/60-1 T3/T4.. With Dual1g Bov's On Daves Upp. Welded center diff , 4bolt rear.. Knife edge/stroked 2.3... lada lada lada bout 23K in just the engine...
David Buschur
David Buschur
So on pump gas 91/93, 264/270 Cams, Cam gears, BOV, M or EBC set around 22-24psi, intake, turbo-back exhaust (minus cat), SFAC and flash. What do you all think the whp would be around?
Originally Posted by zstryder
Jeebus. What dyno was that?
Originally Posted by 03EvolutionVIII
So what HAVE (lol) you done?
I have 272/272 adj cam gears at -2/-4, arp's, hg, intake, magen racing O2, turbo back, hallman, upper i/c, 700cc, 255lph and dynoflash and s-afc
Originally Posted by BlownIncome
Okay then, that makes since. Those are some pretty big numbers with minimal mods IMO, pretty impressive nonetheless. When do you guys expect to get more alky set ups in? Also, have you guys gotten your manifolds in yet for your turbo-kits? I'm actually still a little undecided on the T-67 kit.
Originally Posted by ldstang50
It was on Pruven Performance dyno in CT
