When I stop....washer fluid squirts out
Old Aug 21, 2010 | 09:47 AM
  #91
unitedterra's Avatar
This reminds me of the story about a DSMer removing his rear wiper, but keeping the nozzle and turning it to face backwards for all the tailgaters. It worked so well that he used a fuel pump to get more distance and sprayed anyone that got too close. I hope yours gets fixed though, that would bug the hell out of me if it happened to my car!
Old Sep 4, 2010 | 07:43 PM
  #92
rookievo's Avatar
Problem solved guys. My evo didn't come with the inline check valve or (restictor) read Nasty Evolutions post hes dead on right. After ordering 2 new nozzles, neighborhood auto store restictors, found the solution to it is 2 Joint #3's part number MR388278. The arrow must face into the nozzle when installing. It is circled in the picture.
Old Sep 13, 2010 | 11:48 AM
  #93
Willie Dynamite's Avatar
Good work guys. This 5 year mystery is officially solved.
Old Sep 14, 2010 | 06:27 PM
  #94
Rob W.'s Avatar
THANK YOU! My driver's side has had this problem for months and the passenger just started too. I knew the problem was the restrictors, as I had the same issue with my old 300ZX TT. I read on here that the nozzles fixed it, so I figured the restrictors were integral to the nozzles (and wasted $25 on a driver's side nozzle that didn't fix the problem). Finally, with your help, I now have the part number and have ordered some replacements.
Old Sep 15, 2010 | 10:10 PM
  #95
rookievo's Avatar
I searched this problem trying to figure out for days. I was told to also purchase 2 new nozzles installed them and called it a day, but nope it still was leaking, wasted money spent. I then tried to search for photos of evos with their hoods up closely to where I can see the nozzles but no luck. Until I found this thread where you can replace your nozzles with galant nozzles. It showed the configuration of under the hood and I was able to see that mines didn't have the restrictor. Then it made sense to me i was missing that part all along. Man I almost just about to give in to not even use my wipers. I am glad that this issue is fixed.
Old Sep 15, 2010 | 11:18 PM
  #96
white8's Avatar
THANKYOU!!!!!!!!!!!!!!!!! I had orange washer fluid spraying all over my white hood all summer.
Old Sep 16, 2010 | 10:42 AM
  #97
javicracer's Avatar
wow i have the same problem!!!! i can fix it now.
Old Sep 17, 2010 | 11:58 AM
  #98
Man on a white car that has to really suck. My Evo was BBY so the blue washer fluid wasn't really noticeable from more that a few feet.
Old Sep 17, 2010 | 12:02 PM
  #99
EVO8STI's Avatar
damn that was really simple. im gonna go make sure mine has them on it so it doesn't happen to me. good info
Old May 28, 2011 | 04:03 PM
  #100
luckybull's Avatar
bump. going to look for the check valves at the auto parts store in a bit. **** is annoying!
Old May 28, 2011 | 04:13 PM
  #101
rileyschroeder's Avatar
i would love to see this i bet its funnny
Old May 28, 2011 | 09:54 PM
  #102
dee242's Avatar
your evo threw up looking at your ugly face
Old Sep 20, 2011 | 01:53 PM
  #103
jr_2006IXMR's Avatar
ruined my cf hood having this problem hopefully it gets fixed with this solution.
Old Sep 20, 2011 | 08:53 PM
  #104
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
I just noticed my car doing this at the last autox event. My reservoir was a lot more full than normal though. I'll check out the fixes.
Old Sep 20, 2011 | 11:09 PM
  #105
FERNO's Avatar
LOLWUT.
Now we can all sleep better and move onto more pressing issues, such as: My taillights always fall out of my car when I hit the gas. Do you think it might be a bulb or the rubber pad on the accelerator pedal?
