Help with Wiring...
Old May 4, 2005 | 10:02 AM
Santhology's Avatar
Help with Wiring...
I already did a search but it doesnt really explain it that well. I just got a Greddy Boost gauge and everything is installed it took me like 15 minutes, the only thing is that iam not sure were the wires go.. how do i connect them??, Where??? i also have these sort of Pink plastic things that iam not sure what they are for if someone could show me some Pics that would be better that way i can find it on my car..
Thanks for the Help...
Old May 4, 2005 | 10:23 AM
bigjhoney's Avatar
Im guessing your talking about the electrical wiring. Power: Theirs a panel where you can adjust the dash lights, level of the hid's ( left side of the steering wheel directly under the heater vent). Bend down and look from under the dash and you can see a harness connected to the panel I was talking about. Theirs alot of wires, but the one you need to splice into is a green and white one. For ground: if you open your drivers door look into the car where the door would normally cover if it was closed, you should see a panel, its the only one. Pull it out and you will see a bolt thats screwed in there. Run the wire from under the dash and hook it up to this bolt, close the panel. It should all work then. Pm me if you have any other questions.
Old May 4, 2005 | 10:52 AM
Santhology's Avatar
Thanks .. yeah its a Electrical Boost gauge and it requires a 12v and a ignition, and brake light, and ground... those are the ones that i need iam just not sure were to conect them.. though your Reply does help.. just wondering would you happen to have any pic of this that way i can actually put them together??
Old May 4, 2005 | 11:09 AM
bigjhoney's Avatar
If no 1 else gets any pics up before, ill post some up around 4 ( for you it would be 1).
Old May 4, 2005 | 12:52 PM
bigjhoney's Avatar
Check this thread out, plenty of pics...https://www.evolutionm.net/forums/sh...ad.php?t=98114
Old May 4, 2005 | 03:06 PM
Santhology's Avatar
Ahhh .. yeah thats it... thanks for actually taking your time to post...
Old May 4, 2005 | 03:11 PM
bigjhoney's Avatar
No Prob., I would of done it earlier, but my work computer is from the late 80's and freezes when I try to search.
Old May 4, 2005 | 04:39 PM
Santhology's Avatar
One thing though.. i have the greddy boost gauge and it comes with 4 wires... 12v power source, ignition line, Parking light line, and ground!!
That only connects 2 wires
