I need Expert Advise here Plz!!!
Old May 5, 2005 | 08:31 AM
8ASTI's Avatar
Question I need Expert Advise here Plz!!!
I really need some expert advice on what really works as giving me some bigger HP/TQ numbers. I want to do one more mod and a reflash within the next 2 weeks and I have no clue what the mod should be. I am looking to spend no more than $500.00 on the mod. I currently have:
Buschur upper IC
HKS 272/272
Buschur turbo back with cat delete
maual boost controller
buschur intake
alky injection
255 fuel pump
Custom Dynoflash
I am running 23 psi at the track should I get biiger injectors next maybe??
I appreciate any input on this. Thanks!!!
Old May 5, 2005 | 08:34 AM
Event-Horizon's Avatar
10.5 hotside $500.00 should include parts and install. Good results in the mid range and top end. 10-20whp ( need a tune too )
Old May 5, 2005 | 08:36 AM
jj_008's Avatar
+1
Old May 5, 2005 | 08:56 AM
8ASTI's Avatar
so 10.5 hotside what about injectors you think I need them?
Old May 5, 2005 | 08:59 AM
JeffR116's Avatar
Only if you're upgrading the turbo.
4-BNGR's Avatar
Lower IC pipe $200 and 10.5 housing $295
Old May 5, 2005 | 09:04 AM
ct9a gsr's Avatar
buschur deluxe FMIC and spike the boost as high as you feel safe doing so, tapering down at redline...
if you're sticking with stock turbo, there is absolutely no need for bigger injectors... you won't make any extra power... ESPECIALLY with your DynoFlash and alky injection.
Old May 5, 2005 | 09:08 AM
8ASTI's Avatar
Thanks for the info. everyone I am thinking my best bet is the 10.5 hotside and Lower IC piping or ported o2 housing? Then send the car out for another custom reflash.
Old May 5, 2005 | 09:27 AM
The ported O2, or a 3" O2 housing like Helix makes will be a good combo for the 10.5 as it helps to offset the 200rpm or so slower spool. With the 10.5 and O2 housing turbo, spool will be stock.
Old May 5, 2005 | 12:17 PM
KILTERMAN's Avatar
didnt read his mods
Old May 5, 2005 | 12:23 PM
TRDHarrier's Avatar
well, it's safer to run bigger injectors since you are runnning at least 90% duty of your stockers.
Old May 5, 2005 | 12:28 PM
SterlingEvo's Avatar
Yeah, lower IC pipe will give you more than the upper did...
Old May 5, 2005 | 12:46 PM
Jakeg97's Avatar
some cool stickers
Old May 5, 2005 | 12:52 PM
anjapower's Avatar
nawz and neons.
Old May 5, 2005 | 02:10 PM
chills's Avatar
when looking for a 10.5 hotside... what exactly is the part called? I have been wanting to get this but don't know what too look for exactly...
