03 Evo Viii
Old May 5, 2005 | 11:00 PM
bluebanana23's Avatar
no problems yet but the gears are very notchy
Old May 6, 2005 | 05:34 AM
Kayaalp's Avatar
Originally Posted by li1p1aya
I'm planning to get a stock 03 evo VIII with 12,000 miles on it. Is the 03 evo as bad as it seems? synchros bad, clutch wearing out, rpm rises for no reason?
The RPM rising issue is a problem with '05 Evos...that's not an '03 Evo problem. Stock clutches will last forever as long as you know how to drive (unfortunately, many people don't!). I have over 22K on my car and I regularly drive the thing on the track (real racetrack...not dragstrip) and I don't have any clutch problems at all. It feels as good as it did brand new. But I never drop the clutch or launch the car...ever.
The only major issue with the '03 Evos was the open diff seems to accelerate wear on the t-case. The solution is to flush your t-case with new gear lube with every second oil change. You MUST use Mitsubishi DiaQueen LSD Gear Lube. It's a DL-5 lube with SAE-90 rating. DO NOT let your Mitsu dealer use the generic DL-4 SAE 75-90 lube they use on regular Lancers. If they do...the t-case WILL fail. I had TWO separate dealers make this mistake and they ruined TWO t-cases! Both were replaced under warranty.
I want to pick up this car cause it stock and doesn't seem like the guy beat the hell out of it but worried about the problems that may arise and the dealer voiding my warranty.
Just take the VIN to any Mitsu dealer and have them run it on the computer. If there are any warranty problems/restrictions that will come up.
I dont plan on doing any mods till the end of this year.
Good luck with that
Emre
4ag18psi
11
Aug 5, 2011 12:40 PM
Zac_o
Mar 31, 2009 03:35 AM
partyboy1122
Sep 14, 2007 03:42 PM
dairyman
Mar 21, 2006 07:21 PM
Steiner
Oct 29, 2004 11:04 AM
