Did Your Buschur racing tb exhaust come with gaskets to seal inbetween the flanges?
Old May 13, 2005 | 08:05 PM
BoostWhore's Avatar
Just got my buschur racing tb exhaust but it didnt come with any type of seals to go inbetween the flanged exhaust pipes am i missing them or is this the way its suppose to be. I know the dp @ the 02 housing doesnt use one but im not sure about the others
Old May 13, 2005 | 08:36 PM
gonzo's Avatar
No it doesn't come with one. I went ahead and put a gasket on there, but from what I was told, it isn't needed.
Hiboost's Avatar
There should have been a few pages of instructions included wih the exhaust that said the leaks would be non-existant or very minor. Since I like things to end up being perfect I sanded the mating surfaces flat with a few passes of emery cloth. Either way you should be fine with no gasket. Worse case is you hunt down a 3" exhaust gasket and remove a couple bolts to slip it in but the flanges look clean enough to just bolt them together.
Old May 14, 2005 | 12:17 AM
Jakeg97's Avatar
if you want your exhaust system to have a gasket seal, like i did, go to your local auto parts store and purchase some gasket. you just have to cut what size you want
