Greddy BOV
Old May 15, 2005 | 07:20 PM
Nvr2old32's Avatar
Greddy BOV
Question?
Just had a Greddy bov installed and am noticing that when I come out of gear to slow down, my idle drops real..... low - almost to stall but then comes back up to normal. Which way should I adjust the valve (allen nut) to correct this issue? Soft or is hard or tight - Can't remember.
Thanks for the help!
Also, my boost is set at 20 psi. My current mods are just the drop in filter, ebc, greddy catback - Is this amount of boost too much or fine? (I don't get on it that much but want to make sure it's ok when I do)
Old May 15, 2005 | 07:50 PM
mooreboost's Avatar
No one has much like with that valve. Run a search, you may be able to help it alittle by adjusting the nut, but I doubt it.
Old May 15, 2005 | 07:53 PM
11secEvo05's Avatar
Are you running vta or rec. ?? If your running vta then your idle is going to drop since the maf sensor is reading diff what is actually going in and confused the ecu but i would rec. going rec Thats the best Way
Old May 15, 2005 | 07:54 PM
evolved8's Avatar
i have that same problem, but i never had it before i installed my injen intake. i dont think its the greddy, as i have a type s and it was perfectly fine with the stock intake, but not loud enough for me. so i went with the injen and it drops real low coming out of gear...
Old May 15, 2005 | 08:06 PM
Nvr2old32's Avatar
I'm currently recirculating. I called the guy that installed the bov and he said to tighten the nut, so I did, but it didn't help.
I didn't have this issue with the stock bov so there's got to be a way to correct this.
Old May 15, 2005 | 08:11 PM
Warrtalon's Avatar
You can't expect it to behave like the stock BOV...you replaced it so that it WOULDN'T be the same, right? These things happen when you mess with parts unnecessarily.
Old May 15, 2005 | 08:17 PM
Willie Dynamite's Avatar
I have a Greddy type s with an Injen intake and upper pipe and all things are fine for me.
Old May 15, 2005 | 09:00 PM
Jakeg97's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=113527
Old May 16, 2005 | 04:08 PM
mdosu's Avatar
it's on a bit too tight, turn it to soft...but make sure you're still hitting 20 psi of boost after you adjust it...if your ebc is set to 20 and you adjust it and run let's say 17, then you've turned it too loose...it's lots of playing around.
Old May 16, 2005 | 04:33 PM
si_eater's Avatar
if your talking about the type-s did you do the single spring mod
Old May 16, 2005 | 04:50 PM
mobounce's Avatar
same EXACT situation for me after I installed the injen intake... when i had the stock rubber piping on, my greddy typ-s was just fine...hmmmm
Old May 16, 2005 | 05:01 PM
si_eater's Avatar
i have the buschur intake and filter with the greddy type-s but i did the single spring mod before i put it on and it works great loud wistle, no idle problems what so ever
