new to mitsubitshi
Old May 17, 2005 | 10:12 AM
honda-guy's Avatar
Well, whatever, it's your money to waste. If your mind is made up, don't ask for advice...I just wasted my time answering your questions for naught.
i appreciate your advice and i don't mean to be a smart ***. i'm not look for just top end power, i want a broader power band with more under the curve power and tubular mani and BB turbo would increase low end if you stay with a small turbo. i'm used to having instant power when i hit the gas coming from NA hondas, even with my 300 whp 1.6L boosted honda there wasn't that much lag. and if i can make 350whp with minimal boost vs. 25+ psi, that would be better for engine longevity.
Old May 17, 2005 | 10:21 AM
Warrtalon's Avatar
That's exactly the purpose of the stock turbo and is what we've been trying to tell you. It is NOT made for top end and makes WONDERFUL torque due to how early in the RPMs it provides boost. You can get your 350whp without going over 25psi, because the stock turbo doesn't even FLOW well above 24psi. You can also go with 264/264 cams that are designed more for torque than outright hp, since you seem to prefer that route.
Old May 17, 2005 | 10:35 AM
HiHeatEVO's Avatar
get some cams for the low end torque.
I think the turbo spools fairly quickly considering how much boost we push. You're wasting money to get another small ball bearing turbo. Just learn how to drive the car instead of trying to make it drive like a HONDA. Good choice with the EVO.
Old May 17, 2005 | 05:54 PM
honda-guy's Avatar
sounds good, i'm going to put cams and cam gears first on my list. thanks for the help.
