jacking up the car
Old Jul 18, 2005 | 12:52 AM
  #46
Jakeg97's Avatar
Old Jul 18, 2005 | 04:52 PM
  #47
KEVO8's Avatar
EVO8LTW,
Do you have the specific name for the block in your photo? That is something I'd like to order form JCWhitney but I can not find it on their web site.
Old Jul 19, 2005 | 05:12 AM
  #48
MarkDK1's Avatar
I called JC Whitney a couple of months ago - they don't carry it any more - I had a supervisor double check the sales person.
I searched the internet and found another company that sells something similar for aboput $20 - I think I used google and searched "Jack block."
Old Jul 19, 2005 | 05:52 AM
  #49
KEVO8's Avatar
Yeah I did a seach too and found similar products, but I really liked that one. And for six bucks, you can't beat it. Oh well, maybe I'll end up making my own.
Old Jul 19, 2005 | 12:07 PM
  #50
Jakeg97's Avatar
Originally Posted by EVO8LTW
This is what I use. You can jack at the factory points without damaging the car. It's from JC Whitney and cost less than $6.
or a piece of wood
Old Aug 8, 2005 | 08:25 PM
  #51
w8less1der's Avatar
For those of you that have Rhino Ramps, do you use the 8000 or 12000? By the looks of the 8000s, the Evo tires are too wide for them.
Does anyone have a real life picture of the center front jack point?
Old Sep 2, 2005 | 08:10 AM
  #52
letMeIn's Avatar
or you can build your own ramp
http://www.mustangworld.com/ourpics/News/mwramps/
Old Sep 2, 2005 | 01:51 PM
  #53
w8less1der's Avatar
I ended up buying the Rhino Ramp 1200s. They are barely wide enough to get the tires on and you have to jack the car up and slide the ramps underneath the tires. Make sure you have jack that can lift the car up more than 18-1/2 in. because with my floor jack we had to jack the car up to the max (18-1/2 in.) and then have someone lift the wheel up to get the ramps underneath each of the rear wheels.
Old Sep 2, 2005 | 06:55 PM
  #54
byt's Avatar
byt
dig a pit
Old Sep 2, 2005 | 10:20 PM
  #55
TomSlick's Avatar
I use some 1/2 inch scrap plywood 6" square 2 pieces per pad cut 1 to make two 2 and 3/4 x3" pieces screw them together. so there is a slot in the middle for the seam car goes up no damage.
_____ ______
|_____|_|______|
|_____________|
Old Jul 22, 2008 | 10:29 AM
  #56
TurboTylerIX's Avatar
_____ ______
|_____|_|______|
|_____________|
Wood isnt the safest material to use, it has cracked for too many people. Especially when you cut a slot in it you create a huge weak point. if you use an unmodified 2x4 or 4x4 or whatever you should be fine...but when you go cutting a slot in it, it becomes unsafe. We need to keep people safe while under their cars.
These seem like great products. Check to make sure it will fit your jack before you buy it.
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
https://www.autobodytoolmart.com/pc-...k-adapter.aspx
Old Jul 22, 2008 | 10:55 AM
  #57
Dr. SS's Avatar
Originally Posted by BoostWhore
I would personally jack from the suspension arm mount points its a lot more sturdy plus it doesnt chew it up. Nobody may see it yeah but if u bend it all up the paint will chip on it and cause it to rust...
word, i only use a arm joints or frame points. i would avoid the stock jack points.
i also use my jackstands in those positions. but about 85% of the time i use rhino ramps.
if i want to lift the whole car like when doing an exhaust, ill drive the front up on rhino ramps, and then jack up the back and put the ramps under the back the wheels. whole car is lifted with no stands or jacks to worry about.
Old Jul 22, 2008 | 11:18 AM
  #58
Ev0cRaZy's Avatar
LOL @ brought back thread from Sep. 05
Old Jul 22, 2008 | 11:27 AM
  #59
TomSlick's Avatar
That was a while ago. Now I use Machined Delrin Pads
Now I use Machined Delrin Pads, thicker same design with deep cup To make sure in can not slip off of the Jack Pad.
TomSlick
Old Jul 22, 2008 | 01:32 PM
  #60
salukidude's Avatar
I'm pretty sure no one has gotten crushed in the three years since this thread was posted to last. Way to dig it up though man!!
