Help !
Old May 20, 2005 | 08:01 PM
dani6785's Avatar
Help !
After a long week I just finshed installing my clutch but am stuck in with a broken transfer case oil seal and bearing passenger side, I have called the dealership but they refused to sell the oil seal or tc bearing .I have looked everywhere I am so tired smelly and cut up I just want to drive my evo Is there any alternative ? Can I use a differnt type of bearing and oil seal for my TC ? If not where can I get one ? This is a scan the dealership gave me The circle is the bearing I need and seal
Thanks
Old May 20, 2005 | 10:35 PM
timzcat's Avatar
That picture is a rear differential, not a t case.
Old May 20, 2005 | 10:51 PM
DaWorstPlaya's Avatar
^^^ Thats what I was thinking.
You could try:
Teamrip (www.teamrip.com)
John Sheppard (www.shepracing.com)
Roadraceengineering.com
Goodluck ...
Old May 20, 2005 | 11:44 PM
blueo4's Avatar
You could try:
Goodluck ...
try another dealership
Old May 20, 2005 | 11:52 PM
PoorBoys's Avatar
Heh, that might be reason #1 why the install went wrong....
Old May 21, 2005 | 07:58 AM
dani6785's Avatar
Thanks guys
. I was wondering if I can use a Eclipse a Differential Bearing http://www.roadraceengineering.com/quaife.htm .Also What is a O-Ring: MD727944 is that a bearing for my tc ? And If anyone knows the part number to a Oil seal for my TC I will paypal em some money Im sorry for the trouble
Thanks guys I apresheate It
Danny
Old May 21, 2005 | 09:51 AM
Just call up those sites I listed and talk to them, they can probably get you the part you need ....
Old May 24, 2005 | 04:42 AM
Jakeg97's Avatar
oh boy....
Old May 24, 2005 | 05:51 AM
sabastian458's Avatar
here, the o-ring between the t/f case and trany MD727944, the oil seal for the shaft between the t/f case and trany MR980100 and the oil seal between the t/f case and right axle MD755526 now on the bearing, those t/f cases are not serviceable thru mitsu so you will need to remove the old bearing and take it to either a parts store or to a shop that specializes in rebuilding of manual transmissions. hope this helps
