Fq-400 Whp?
Old May 21, 2005 | 04:42 PM
neonsalamander's Avatar
Fq-400 Whp?
Hey guys I just watched some Top Gear vid's on the MR FQ-400 and was curious as to the WHP rating on this car. Is it in fact 400 WHP or is that how much it is making at the crank? By the way it performs I wouldn't be surprised if it was 400 whp...
Old May 21, 2005 | 04:44 PM
MTMS4's Avatar
crank
Old May 21, 2005 | 04:59 PM
mike69's Avatar
That's sad. Even with a bigger turbo, they can only get 400 at the crank? Isn't there someone on here with like 450whp on the stock turbo?
Old May 21, 2005 | 05:00 PM
Mivo's Avatar
yep manufatuers never rate the hp at the wheels its usually crank.
Old May 21, 2005 | 05:14 PM
EVO8868's Avatar
Quite true. But there are instances where some manufacturers underrate the hp and the rated hp is closer to the whp than crank hp.
Old May 21, 2005 | 05:49 PM
bigjhoney's Avatar
Take the regular us evo 8, its detuned and runs ruch as hell from the factory so the car will last longer and be more reliable( mostly warranty purposes). Same thing is done to the fq, its a badass car with a warranty, and detuned for reliability and also for warranty, they want it to last atleast 3 years or however long your warranty is for.
Old May 21, 2005 | 05:53 PM
mike69's Avatar
*cough* SRT-4 *cough*
Old May 21, 2005 | 06:13 PM
So technically, if I was to get Vishnu Stage 1+ (and get about 390 crank hp) my car would be just about as fast as a FQ-400?
Old May 21, 2005 | 06:27 PM
Imyurturboluva's Avatar
Yep, and ad in a 10.5 hotside, and intercooler...you'll be way quicker than the FQ400. I just love my FQ400 esq...Look out Lambos!
Old May 21, 2005 | 06:47 PM
housedj's Avatar
Thumbs up
not to mention for the price of 1 FQ400 ($91k) you could buy 2 evo's & make them BOTH faster & handle better. that's 1 of my goals & the reason for having 2.
Old May 21, 2005 | 06:52 PM
EVO8868's Avatar
Yep, that's exactly the vehicle I had in mind. I believe the 03/04 Cobras' whp are very close to manufacturer hp rating as well.
hi_nrg_fizzix's Avatar
Interesting article about FQ400 vs FQ320:
http://www.lancerregister.com/art_fq400report.php
Old May 22, 2005 | 01:45 AM
Mivo's Avatar
not 100% true. i doesnt matter if you have 200hp or 600hp that doesnt rate how fast you are. the only thing that matters is how/if you can put the power to the ground and get it out properly (ie not chirping the tires) i am not sure if they updated anything on the fq400 that we dont have on our evo 8 here but if u get stage 1 yes u will have about the same power will you be almost as fast? the world may never know
Old May 22, 2005 | 05:04 AM
HxllxMan's Avatar
don't forget to improve the handling/braking...
You will ptobsbly go at the same speed between the corners, but how about in the corners?
Old May 22, 2005 | 05:18 AM
mifesto's Avatar
dont forget the FQ's are also MR's so they have 6 speed and bilsteins... now if you take a 2003 GSR such as mine and make the same amount of power, the FQ still has an edge in power delivery and handling.
