question about bov and mbc
Old May 31, 2005 | 04:37 PM
Evo#1's Avatar
Does the Greddy type s bov recirculate or do I have to buy a kit to do that.
and I was looking at this MBC, I was told it is one of the best from a guy down at the track.
O r should I stick with hallman mbc
Old May 31, 2005 | 04:41 PM
ddubb's Avatar
the greddy type-s bov is already set up for recirc. all you will need to get is the bolt on flange kit and you're set. look on lancershop.com i think they are selling the two as a set.
Old May 31, 2005 | 04:42 PM
myblk03evo's Avatar
well greddy has discontinued the type s and it DOESNT recirculate. i have the Turbo XS rbv-h34 bov. its incrediable and it recirculates as well. the best bov IMO!!!! great price too.
Old May 31, 2005 | 04:47 PM
ddubb's Avatar
you must mean that the new greddy bov that replaces the type-s doesn't recir b/c i run the type-s and it def is recirc. without any other kit. If you use the type-s and vta you will have idle issues. if you do go with the greddy make sure you do the singe spring mod. Search and you will find all the info on the type-s bov
Old May 31, 2005 | 04:48 PM
Evo#1's Avatar
well what is a good direct replacement bov then
Old May 31, 2005 | 04:51 PM
ddubb's Avatar
imo this is a very personal decision depending on what you want. I think it has been talked about a lot that the greddy type-s is a great bov for ricirc but you don't get the loudest blow off sound that you might get with others out there. not saying this only b/c i own one i or my firends have also run the gfb and hks, jsut like the greddy better, IMO. Try doing a search b/c there is so much info already there on all kinds
Old May 31, 2005 | 04:55 PM
Evo#1's Avatar
I just want a bov that will hold up under more pressure and is a direct replacement,
and if it make my car sound cooler than thats just a plus.
Old May 31, 2005 | 04:58 PM
ddubb's Avatar
then get the greddy type-s, installed min in 15 min with the bolt on flange, bolt up to all factory piping easily. holds boost very well and don't have any idling issues. Don't take my work for it though, search and see what others say and see what you like the best.
Old May 31, 2005 | 05:02 PM
Evo#1's Avatar
well it seems I can get one for pritty good deal thats why I want to know,
btw what is a bolt on flange, any links to were Ican get one
Old May 31, 2005 | 05:06 PM
ddubb's Avatar
look on lancershop or most any other retailer on this forum. Lancershop has a good picture of it. Simple piece that bolts to the bottom of the bov and has a flange that will fit directly to the piping so that you don't have to solder anything. I bought mine used too so I just ordered the flange from lancershop. You will be happy
Old May 31, 2005 | 05:09 PM
bdking57's Avatar
works rally concluded the GoFastBits bov was the best on the market.. most flexible and spring tension increases by turning a knob.. plus it has 16 positions of recirculate to vta ratios you can run, include full recirculate.
Old May 31, 2005 | 05:17 PM
ddubb's Avatar
do you know if GFB makes more than one model? my friend ran the red one that sounds like the one you are referring to but on all settings he still had some issues so he changed too. Are you running the GFB, how do you like it?
Old May 31, 2005 | 07:23 PM
qbbraveheart's Avatar
wErd!
got mine from them...great customer service, fast shipping and I have no problems with my typeS
Old Jun 1, 2005 | 10:53 AM
ddubb's Avatar
hey evo#1, saw this today thought you might want to check it out for more info if you haven't already bought your BOV
GReddy Type S BOV EVO 8 Kits - Few Left (36)
shows a good pic with the bolt on flange attached.
Old Jun 1, 2005 | 10:55 AM
bdking57's Avatar
gfb does have a cheap model.. the one you want is the stealth FX..
